Hi. My guage mounting plate seems has just recently started vibrating on me. There are two bolts in lower left and right hand corners but I can't see if there are nuts at the bottom. I tried tightening them and they rotated but they didn't move really easily. is the whole system self tightening? thx
Gaugepack question
Gaugepack question
79 XS1100F "JINGUS"
07 V-star 1100
Do you want it done right or do you want me to do it?Tags: None -
There are nuts on the bottom of those bolts and the bolts go through a damper with metal insert. If you lost a nut, then things are going to get lose and you may lose parts of the dampeners.
I believe both the nut and the bolt are 10mm.1979 XS11F Standard - Maya - 1196cc (out of order)
http://www.livejournal.com/~xs11 -
