Will an XS1100 Airbox fit an XJ1100
  • davidsymons53
    • 197
    • Peterborough, Ontario
    Will an XS1100 airbox fit an XJ1100?
    1981 XS1100 Special
    Previous Bikes
    1999 Honda Goldwing Aspencade 1500
    1983 Honda Goldwing Aspencade 1100
    1982 Honda CB900c
    1984 Honda vt750 Shadow. My son's bike now.
    1984 Honda vt500 Shadow
  • Yahman
    • Mar 2008
    • 779
    • Salem, OR
    Not that I'm aware of, there are too many differences between the frames.
    Larry
    82 XJ1100
    80 XS1100G (Project bike)
    64 Yamaha YA-6
    77 Suzuki TS-185
      All I know for sure is that the XJ folks say their air box makes pulling carbs a PITA Plus compared to the XS1100.
      • Jerry
        XS & TRUE XJ GURU
        • 3023
        • Elma, IA.
        As a bolt-on mod, no. From memory, the XJ carbs use a 34 vs 32 mm inlet bell. You might be able to use the XJ inlet boots on the XS air box, but you might have to enlarge the box holes to fit; I don't know if diameter on the air box side is the same between the 2 models. The XJ mounts a bit differently in the frame, again you might be able to fabricate something but it would not be a bolt-in swap.
        If you are looking to do this to get the advantages of a K&N filter, an old thread sows how to use the XJ filter frame to mount a K&N filter element to it. This would replace the dealer-only (and expensive) XJ filter.
        From a post by Maximman:
        Everyone knows K&N made a filter for the XS air box. And...everyone knows they didn't make one for the XJ.
        This is a very simple modification. I took an OEM breather and cut the paper element out leaving the metal frame.
        Then I used a K&N "drop in" panel style filter that was very close to the dimensions of the OEM filter frame. The K&N number is 33-2586. I ordered direct from the K&N website.
        The width was exact. But the length was slightly long by about 1/4 to 3/8 inch. I cut it to length and used RTV to seal it in the frame. Then I used JB Weld to reassemble the frame cross-member to the frame.
        In theory it should allow the engine to breath more readily...but I can't prove that. If I feel like it I do an A-B dyno run while the bike is locked down on the rack to see if there is any difference between the two. I'm not betting it will be discernable but ya never know.
        If you go to individual pod filters, make sure you get the 34 mm ones. Many parts houses get this wrong and list all XS / XJ 1100 carbs as the same size, 32 mm. Even the K&N website has it wrong, showing the XJ uses the same filter as the XS.
        Jerry Fields
        '82 XJ 'Sojourn'
        '06 Concours
        My Galleries Page.
        My Blog Page.
          The carbs are listed as a 32mm carb which is the inside of the carb, not the bell. The bell inlet is 54mm on all the Mikuni 32 carbs. It was once believed on here that earlier carbs had 52mm and the XJ had 54mm... but in fact they are all the same if ordering pod filters.
          • Jerry
            XS & TRUE XJ GURU
            • 3023
            • Elma, IA.
            Thanks for the correction.
            Jerry Fields
            '82 XJ 'Sojourn'
            '06 Concours
            My Galleries Page.
            My Blog Page.
            • nightpilot
              • Feb 2009
              • 87
              • Atlanta
              I might have an extra xj airbox. Not sure if it is complete but if you are interested I may be willing to get rid of it for a reasonable price. it is light and small so I dont think shipping would be much. If you are interested, let me know. I am now using a foam piece for the air filter in mine but am going to look into the K and N referenced above. I dont know what either would do to air flow and know proper air flow is pretty important with these things.
              82 XJ 1100
              98 Magna
              past bikes
              ST1100
              92 Harley FXR built
              85 XJ 700 (2)
              86 XJ 700X
