Re: decreasing port size
I have a idea what decreasing ports size would do would be to increase the vacum on the intake side and would proably allow the motor to run better at low to mid. range.Seems like would have to make the exhaust ports bigger to balance it out.This is way over my head so bare with me.Then could use smaller carbs. or if everything checks out stock.I know if you baby a motor just rebuilt,the rings won`t set and the the thing starts useing oil then ,have do it all over again.Run it hard vary speed and keep a eye on the oil{rings usually set in the first 30 to 45 minutes}.Change the oil at or less than 500 miles because this when the most wear occurs{filter to}
May be they don`t know what their doing,just think they do
.For those who know,I apolgize,the above was for those who don`t.Changing gears,wouldn`t a big bore kit amplify the good points a xs have?Sounds like a winner if done right.
.Actually I have had this nickname from way before I owned my xs.I always liked the power these bikes put out{but would be happy with alot more}.I used to like to lay blackmarks,wheelies were unintentional.I still have the bike,going to fix somethings{plug wires,tires,battery etc.}.Hopefully will be on the road later on. Keep the rubber side down
