I have been finding out horror stories little by little about my 1981 Special I picked up one month ago. Adding to problems with unpaid registration fees, stripped pil filter bolt, over tightened bolts everywhere, now i discovered that the underside of the engine is very wet with oil. (I guess it was dry when I picked it up because it had been sitting for a while...) It is leaking like a GS500 oil pan...I never thought big engine bikes will have this problem.
Is it just a common thing for a 30 year old bike with 40,000 miles on it to have a leaky oil pan gasket, and many of you had changed the oil pan gasket at least once by this point? Or, is it a bad sign of the abuse by previous owners?
I will start by tightening the allen bolts. Is engine degreaser safe to use to clean the mess with?
