Mileage, distance per tank, etc
    Even with recent threads on this, it has only been recently that I finally got a handle on Tsunami's performance.
    Background - ever since we got SWMBO's 'H, it has consistently come in pretty close to 50 mpg (Imp) while Tsunami was always under 40, often closer to 35. During this spring's pre-season preparations, I lowered Tsunami's floats by 2mm so they now measure 27mm from the gasket surface. This brought its mileage up considerably, with 8 fill-ups now averaging out at 45 mpg(Imp).
    Last night for the first time, I actually managed to run Tsunami right to reserve so I could also verify how much is left in the tank "just in case its needed". I had to switch to reserve at 298.4km (186.5 miles), then took on 18.028 litres (3.97 Imp gal, 4.96 US gal). With my 24 litre tank, I now know I've got 6 litres on reserve, which should be good for another 95km (60 miles).
    Bottom line - 'should' be able to run approx 285km (180 miles) before reserve, approx 380km (235 miles) to 'bone dry'.
  • norm_is_here
    • 14
    • Albuquerque, New Mexico
    Hello,
    How do you adjust the floats?
    Norm
    Norm
    XJ1100
    nhs1@comcast.net
    • Bill
      • 368
      • Fairfield, Calif
      Re: Mileage & floats: lean or starving?
      So...you lowered the floats which lowered the fuel level in the float bowls. Enquiring minds want to know:
      • How does that affect mileage?
      • Does it effectively lean out the fuel delivery?
      • Does it cause any high RPM fuel starvation?
      XSerendipity starts quickly and runs smoothly at about 37 MPG(US) or 44 MPG(Imp), but since I added the Road King mufflers it's been a little rich. I'm about to go into the carbs to check everything. I was thinking about:
      • Lowering the needles or
      • Trying smaller jets. (They're currently stock)
      Perhaps I should try setting the floats a little lower before making other changes. Thoughts anyone?
      Bill
      Bill K.
      1985 Yamaha XJ700 Maxim
      1986 Yamaha FZX700 Fazer
      • CA.XSer
        • 189
        • Jerome, ID.
        I get around 30 mpg or less to work on my 79sf. I am running a 4 into 2 Jardine with K&N filter and 140 main jets. The floats are set at 25mm. I went for a ride on Fathers Day (about 130 miles) through the mountains and got 37 mpg. Was suprised the mileage got better as I was on and off the throttle quite abit, with some 15 mph turns and 80 mph straights. I am going to try some 142.5 mains and raise the needle one notch. I belive I will look at changing the float level also to see what happens.
        Gary
        79sf
        78e
        • CA.XSer
          • 189
          • Jerome, ID.
          __________________________________________________ __
          Bill
          Bill
          I think I would try the float setting first. It is my understanding that float settings effect the the cruise range. My .02
          Gary
          79sf
          78e
          • Mike Hart
            • 1025
            • Seattle, Washington
            Bill - floats or mains?
            Bill, IMO, adjusting floats is a tweak, and the last thing you do.
            Those hd pipes must be more restrictive than stockers, indicating
            you should first change the mains.
            btw, someone recently reposted Denny's chart of how to change
            jets according to various mods, I will mail it to you offline, you
            could put it in the carb section.
              Re: Mileage, distance per tank, etc
              Originally posted by norm_is_here
              Hello,
              Norm
              Carefully!
              Really, Norm, you set the carb bank upside-down with the float bowls removed and gently bend the small tang that presses against the end of needle valve. I then use a digital caliper to check the height.
                Re: Re: Mileage & floats: lean or starving?
                • For Tsunami, mileage increased by about 20-25 percent
                • Yes, fuel delivery was leaned out, which is exactly what I was looking for. Last year, driving at elevation in Colorado, I had quite a bit of trouble with fouled, black plugs. Even hack at home, the plugs were still too dark even with the 120 mains all across.
                • No fuel starvation noted, at least not the way I drive. I've probably only pushed to to about 7500 rpm, and it was doing just fine then.
                • Bill
                  • 368
                  • Fairfield, Calif
                  Re: Bill - floats or mains?
                  Mike Hart wrote:
                  btw, someone recently reposted Denny's chart of how to change jets according to various mods, I will mail it to you offline, you could put it in the carb section.
                  Great stuff, for sure! I saved it and started working it into a tech tip. JP thought maybe it needed some pix or review from the original author. However, last I contacted DZ he didn't seem interested in getting involved with the group. Who knows, maybe the forum would be more to his liking?
                  Bill
                  Bill K.
                  • Mike Hart
                    • 1025
                    Denny's jetting tips
                    Bill, I notified Denny about the forum. He apparently looked in
                    as guest, since he told me it was cool and he'd keep an eye on it.
                    I'm in fairly regular contact with him, you want me to ask him for
                    permission / review? I doubt he would mind if you emailed him,
                    but I can do it if you like.
                    • Yetti
                      • 6
                      • VA
                      When I bought my '79XS. It would not idle. A "thorough" cleaning and adjustments to the floats cleared this right up. I also bought a mercury level sync. gauge. I am currently getting about 33/34 miles to the gallon.
                      Yetti
                      • Robert Haller
                        • 356
                        • Atlanta, GA
                        On a ride in the mountains this weekend I got 43.75 mpg on a tank (usually get 38 mpg for all city riding). All the carb stuff is stock but have a Jardine 4-1 exhaust and K&N stock filter. I thought that I would have to rejet but my headers are just ever so slightly turning gold after 3000 miles. That's a pretty good sign isn't it? I have yet to pull the plugs after killing the engine to check condition.
                        Robert
                        79 SF
                        • kenkrieger
                          • 123
                          • Transplanted to Virginia
                          This is good info,,,,I get just 30 mpg,,,,,,81 SH,,all stock and the carbs might be clean,,,,it was setup using the Yetti's mercury gauges,,,,never set the float height,,,,,,,,looks like I have some work to do. the bike runs great,and quite fast. But some of these mileages are way higher. I was able to get a high of 39 mpg last year at XSEast 2001 riding in the White Mountains,,,,,but never again.
                          Ken Krieger
                          Chesterfield, Va.
                          81 XS1100SH - Radar Rider
                          82 XJ1100J - Black and Blue
                          82 XJ1100J - Bucket o Bolts
                          79 XS1100SF - Road Raider
                          1980 XS1100 - Frankenbike
                          85 XJ700 Maxim
                          06 VMax - Black Max
                          85 650 Nighthawk
                            • 5062
                            Yep, that is good! What carb settings/jetting are you using?What elevation are you running?
                            • Robert Haller
                              • 356
                              • Atlanta, GA
                              Skids,
                              All my carb settings/jetting are stock for a 79 Special (I don't have the actual specs with me). The 43.75 mpg was unusually good, normally I get 37 - 41 mpg depending on the mix of city and highway riding I do. My city (Atlanta, GA) elevation is about 1000' and the mountain riding I do in North GA is 2000' - 3000'.
                              After adding the K&N stock filter and Jardine 4-1 exhaust, I am really hoping to get input to determine if I need to change my carb settings or jetting. I would prefer not to mess with it if I don't have to, but will if I do. My bike seems to run pretty well now, but I don't know how much rejetting may improve.
                              Robert
                              79 SF
