I am trying to get my 79f running and me and scott deduced that one of my coils had bad caps , but still not idleing , we tried to sync it but it is spitting thru the carbs and also no vac at idle speed ?? Any ideas??
no vacuum @ idle?
When I was running the early cams from a '78 in my later motor, I had almost no vacuum. I'm not saying this for you to supect the cams, but apparently the timing has a huge part in this. When I put in the late model cams right after that, my vacuum rose a LOT.
So.. maybe with spitting and this vacuum problem.. you might start with your timing and make sure everything is on the marks and lines up. Including taking the valve cover off and checking the cams against your crank.
Just a suggestion. I'd start under just the timing cover first though. Something may be hanging your timing up in the advanced. I know those bearings that let the timing assembly move go bad sometimes.
*Crashed/Totalled, still own -
Had the hose pull loose at the vacuum advance. Gave me fits till I found it. Simple to check.'81 1100 MNS - "Midnight XSpress"
Original except:
Big JohnComment
timing
Yeah that was my first thought too , but the timing checked out so far - I guess I am going to peel off the valve cover, scott thought I might have a hot cam as well , I will find out when I dig a little deeper and check valve clearances , this bike is pretty stock now but the PO was kind of a hot rodder. How can I check the cam itself?91 kwaka kz1000p
Stock
( Insert clever quote here )Comment
1/4
This set of carbs is off a 80g. With stock jetting. And pilots turned out 1/4 turn. I am going to tune up my 79 carbs and see if the vacuum changes as well I don't really want to mess witht valves this bike is for sale and I really don't want to spend much more money on it91 kwaka kz1000p
Stock
How can I check the cam itself?I think I have a loose screw behind the handlebars.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesComment
This set of carbs is off a 80g. With stock jetting. And pilots turned out 1/4 turn. I am going to tune up my 79 carbs and see if the vacuum changes as well I don't really want to mess witht valves this bike is for sale and I really don't want to spend much more money on itCy
Yeah, the 78/79 cams will have 2H7 stamped on them and the 80/81s and the XJs have 3H5.
Have you done a compression check?
negative
not yet maybe when I get back , this bike sat for at least 8 years without running , I did the usual MMV in the cylinder trick , and it turns freely and when it did run it didnt seem to burn oil91 kwaka kz1000p
Stock
Garthxs, try running idle mix screws out to 2 1/2-3 turns initially.......should help as these are the later carbs.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Low Vacuum
I had a similar problem with my 79F when I bought it. I ended up having to completly rebuild the carbs including shaft seals. I had another set I installed to comfirm my diagnosis and the vacuum was fine. My next thought would be like everyone else... Valves!78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
2006 Roadstar Warrior
http://i408.photobucket.com/albums/p...um/warrior.jpgComment
We had another members bike in Dbeardslee's mancave that had those same symptoms. A new to him "good" engine. Wound up being a bent intake valve.Life is what happens while your planning everything else!
78 XS750Comment
Read through the thread briefly. I usually sync my carbs on 2k rpm. Then adjust my air fuel mixture, and then resync on idle.
Do you have enough vacuum to sync on 2k?'79 XS1100 (2H9) named Bones
1196 Big Bore
4-1 Cowley exhaust
750FD Conversion
Echlin 54mm Racing Cones (Americanese = pods)
Black Ebony Bottled glazed Tank (To be redone now)
BMX footpegs
Tank internally lined (Professionally this time)
GSX400 Throttle bodies (Under serious investigation)
Anti Sticky float bowl systemComment
