Getting New Grips...Size?
  • bwalker
    • Aug 2009
    • 5
    • Delaware
    I'm trying to buy new grips for my xs11 and I'm not sure what size to buy because the throttle grip looks like it is a 1 inch circumference while the left grip looks like a 7/8's. Does anyone know the proper size to buy?
    7/8".........throttle side is bigger as it goes over throttle tube. Comes as pairs.
    • bwalker
      • Aug 2009
      • 5
      • Delaware
      so if i order a set of 7/8's they will fit over the throttle properly? As in, it will be sized right even though it says 7/8 for the pair?
      • Incubus
        • 1003
        • Austin TX
        Yes. That will fit.
        XS11F (Incubus, daily rider)
        1969 Yamaha DT1B
        • bwalker
          • Aug 2009
          • 5
          • Delaware
          Ok thanks for the help.
          • ManitoulinLad
            • 358
            • Manitoulin Island,Ont.,Canada this is in Lake Huron
            Hey BWalker: I'll give you a tip on how to easily install the new grips. This actually can be applied to any rubber parts (side cover rubbers) that need to be streached on for a tight fit. At a local drug store buy some rubbing alcohol. Fill the new grip with it - and then shove it over the bar end. You will have a few seconds to move it around before it sets (the rest of the remainder of the alcohol will evaporate & then the grip will seal). The leftover alcohol will come out the bottom hole in the grip - if no bottom hole then just fill the grip & then dump back out the alcohol & quickly shove it on the bar end ( i would douse the bar end with alcohol too if done this way) I have done this quite a few times & it works slick - cheap too. This method makes the grip very slick to be able to slid it on the bars. This is a trick how they get rubber grips on the ends of gold clubs - Dan
            '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
            1179 big bore kit, 80SG motor
            Rebuilt head, valves
            TC Bros Forward Controls (Brass Pegs)
            Tkat Fork Brace
            T.C. Spade Fuse Box
            Dyna Coils & wires
            Mikesxs shocks,controls,& bars (special)
            ISO grips with stelleto ends
            4 into 1 black Bassani exhaust
            Bridgestone Spitfires
            Tuned by Tinman905
            & a will to keep it.
            • hamjam
              • 1003
              • Toronto ontario Canada
              any one have a trick for removing them without cutting or destroying the old ones??
              thanks
              Seamus Ó hUrmholtaigh
              Niimi Moozhwaagan
              NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
              Any connection between your reality and mine is purely coincidental.
              Member of "FOXS-11" (Former Owner of XS-11)
              and SOXS
              2008 Nomad "Deja Buick'
              • Incubus
                • 1003
                • Austin TX
                If they are rubber grips, I've had success working something thin between the grip and the bar and using dishwashing soap as a lubricant. Pry with a very small screw driver and pour soap do between the grip and the bar, work theat part of the grip and then repeat, trying to get the soap deeper. Then just tug and twist. Hard.
                If they are old, cut them.
                Patrick
                1969 Yamaha DT1B
                  • 2117
                  If you have an air compressor with a blowgun tip take the tip and slightly push it under the rubber and squeeze the handle.The air will push the grip off of the bar.We use that method all the time to attach and reattach rubber pieces where i work.
                    Just do not pry against your turn lights control assembly. The switch will snap right off!
                    • hamjam
                      • 1003
                      skids wrote the stuff above ,which is below some good tips ,
                      good to know and I am not asking
                      thanks
                      jim
                      Niimi Moozhwaagan
                      and SOXS
