This is looking to be a super easy swap on this frame. I am planning on using a 06 R1 front end, but wont have it for a few weeks, but I got my hand on a really cheap 01 front end pieces so i decided to grab them for mock up, and Im sure Ill use them on something. But the stems are the same size, so it doesnt really matter right now. The lower bearing of the R1 is a perfect fit and can be reused. The upper bearing, however is a oddball size 30x47x17. It was hard to track this bearing down, but I believe I have found it to be a pinion bearing in a honda hybrid manual transmission. This bearing is Honda PN 91101-657-014 and available for order here:
The only hangup I have encountered so far is the stem is just a hair too short, so I am going to see if I can get maybe a mm or two down total out of the triples. This shouldnt be too hard at all though. The other issue is that the steering stops just barely touch each other, and the frame stop may need to be shaved a little. So Ill probably need to weld a small extension on it to make sure the stops dont slip past each other.
Ill have the fork tubes here soon.
