engine rebuild
  • Filter
  • engine rebuild
    i was thinking about checking out the gears in my engine while its out and figured i should rebuild it while its apart. the only problem is finding all of the bearings. everything on ebay is very expensive. soes anyone know of an aftermarket source thanks
    Chris
    twitter.com/thechrisdemon -- instagram.com/chrisdemon
    2012 HD FXDC -- bone stock... for now...
    1980 XS1100 Special --
    under restoration for brother
    2010 HD XL1200 -- good riddance...
    1981 KZ650 CSR -- Found a good/new Home
    1980 CX500 -- livin' it up in FL
  • #2
    Crank bearings are still available from Yamaha.. but if you don't like Ebay prices... you're SOL.. lol. My local shop has them for $12.50 a piece.. times 9. Then the saddle bearing is a bit more.
    Rod bearings are unobtainium and Ebay is going to be your only choice for that.
    • #3
      Bearing info
      Fiche No. on fiche Part Name Part Number Comment Replace With
      CLUTCH 14 Bearing (B6003c4) 93306-00304-00 6003 C4
      CRANKCASE 4 Bearing (B4205) 93304-20505-00 Koyo Bearing, Type 4205-INRS S Single row roller bearing, but it comes complete with a locating circlip, fitted into a slot ground into it's outside edge 4205
      CRANKSHAFT - PISTON 4 Plane Bearing, Crankshaft1 2H7-11416-01-00 onwards The numbers on the crankshaft, cases and connecting rods only refer to matching of NEW parts. If any parts are worn then in most cases the thickest bearings will be required to bring it back within specification and compensate for the wear. Blues are best!
      CRANKSHAFT - PISTON 13 Plane Bearing, Connecting Rod 2F3-11656-00-00 onwards See comments above
      FINAL DRIVE GEAR - DRIVESHAFT 8 Bearing 93332-00027-00 Tapered Roller
      FINAL DRIVE GEAR - DRIVESHAFT 9 Bearing 93332-00023-00 Taper cone bearing and cup 32005
      FINAL DRIVE GEAR - DRIVESHAFT 15 Bearing, Cylindrical 93317-41510-00
      FINAL DRIVE GEAR - DRIVESHAFT 18 Bearing, Cylindrical 93316-01403-00 16014C2 110MM 16014
      FINAL DRIVE GEAR - DRIVESHAFT 20 Bearing Assembly 1J7-46106-N0-00
      FRONT WHEEL 5 Bearing (B6302zz) 93306-30309-00 Replace with a bearing with both sides sealed 6302-2RS
      FRONT WHEEL 6 Bearing (B6302z) 93306-30303-00 Replace with a bearing with both sides sealed 6302-2RS
      MIDDLE DRIVE GEAR 5 Bearing (B6305rbi) 93306-30520-00 Split ball race. Marking on bearing reads FAG QJ305 6305RB1
      MIDDLE DRIVE GEAR 7 Bearing (B6006) 93306-00608-00 Ball race. 6006 C3
      MIDDLE DRIVE GEAR 16 Bearing 93332-00028-00 Tapered Roller 15123
      MIDDLE DRIVE GEAR 17 Bearing 93332-00024-00 Tapered Roller 32205XRT-N
      PRIMARY SHAFT - CHAIN 10 Bearing (B6204z) 93306-20426-00 6204 2RS
      PRIMARY SHAFT - CHAIN (all except XJ1100, XS1100 5K7 & RH) 12 Bearing (B4205) 93304-20504-00 18mm wide. 4205
      PRIMARY SHAFT - CHAIN (XJ1100, XS1100 5K7 & RH only) 12 Bearing 93306-20533-00 15mm wide. Slimmer bearing used with a collar 90387-443A8-00 6205
      REAR ARM - SUSPENSION 2 Bearing 93332-00010-00 Swing arm bearings, Tapered Roller. 30203J
      REAR WHEEL 3 Bearing, Cylindrical 93313-62010-00 Yamaha is the only known source for this. 5904
      REAR WHEEL 4 Bearing (B6304z) 93306-30404-00 Marking on bearing reads "Koyo 6304Z". Replace with a bearing with both sides sealed 6304-2RS
      SHIFT CAM - SHIFT FORK 8 Bearing, Cylindrical 93315-23612-00 Cylindrical Roller Bearing
      STEERING 1 Bearing (93332-00001) 93332-00023-00 Upper steering head, Taper cone bearing and cup 32005
      STEERING 2 Bearing 93332-00008-00 Lower steering head, Taper cone bearing and cup, Markings on Bearing read "Koyo Hi Cap 32006 JRRS" 32006
      TRANSMISSION 10 Bearing (B5205) 93305-20506-00 5205
      TRANSMISSION 12 Bearing, Cylindrical 93311-52031-00 Cylindrical Roller Bearing
      TRANSMISSION (all except XJ1100, XS1100 5K7 & RH models) 30 Bearing (B4205) 93304-20504-00 18mm wide. 4205
      TRANSMISSION (XJ1100, XS1100 5K7 & RH models only) 30 Bearing 93306-20533-00 15mm wide. Slimmer bearing used with a collar 90387-443A8-00 6205
      TRANSMISSION 33 Bearing (B6207n) 93306-20705-00 6207 72mm Nt, Deep groove ball bearings, single row, with snap ring groove 6207N
      Notes:
      - The XS1100 G fiche has been used to determine the no. on fiche.
      - Standard bearing acronyms - RS-Rubber Seal, 2RS-Rubber Sealed both sides, Z-Single shielded bearing, ZZ OR ZS-Double Shielded bearing, C3,C4-Clearance ranges
      Rear wheel bearing
      The NA5904 bearing is still being made by NTN Bearings in Japan. It took a while but I just got one through E.B. Atmus Co. (ebatmus.com) for $32.14 plus shipping.
      _____________________________________
      Above from the brit XS site.
      mro
