Intermittent ignition
  • Athedra
    • Oct 2009
    • 221
    • Benoni, South Africa
    During the week, I forgot to refit my right hand screw into the grommet on my side cover. Cover blew off on the highway and with a few bumps and scratches managed to retrieve it.
    Re-fitted it today, and am now having intermittent power on my ignition. While driving, my ignition just switches off, and tapping the right hand cover a few times brings her back to life. Checked the fuse fittings and also the wiring, and cant see anything wrong.
    Any ideas as to why it would be doing this?
    '79 XS1100 (2H9) named Bones
    1196 Big Bore
    4-1 Cowley exhaust
    750FD Conversion
    Echlin 54mm Racing Cones (Americanese = pods)
    Black Ebony Bottled glazed Tank (To be redone now)
    BMX footpegs
    Tank internally lined (Professionally this time)
    GSX400 Throttle bodies (Under serious investigation)
    Anti Sticky float bowl system
  • Athedra
    • Oct 2009
    • 221
    Never mind, found the problem.
    The auxiliary power wires was off at the back, shorting out while driving. Snipped them off, re-soldered them, and is now all ok.
    1196 Big Bore
    4-1 Cowley exhaust
    750FD Conversion
    BMX footpegs
    • mxmikie
      • Aug 2008
      • 482
      • Bouse az
      take a look at the auxiliary power wires at the back,sounds like they are shorting out while you are driving. you might want to trim them off, re-soldered them
        • 1914
        You beat me to it Mikie,
        I was going to suggest that he take a look at the auxiliary power wires at the back,sounds like they are shorting out while you are driving. you might want to trim them off, re-soldered them
        • Athedra
          • Oct 2009
          • 221
          You guys are really good, but what i did was look at teh auxiliary wires, cut snipped them off and re-soldered them. They made a short.
          1196 Big Bore
          4-1 Cowley exhaust
          750FD Conversion
          BMX footpegs
