How to take off side cover?
  • dontlikeoc
    • Nov 2009
    • 173
    • Alhambra, CA
    I have trouble taking off the left side cover(plastic) from an XS1100 Special. I can see the top two being a usual rubber grommets. The bottom one is the one I am having troubles with. It doesnt seem to be grommeted. Neither it pops in/out. Is that bolted?
    Dealing with a 30 year old plastic, I dont want to risk breaking it.
    dontlikeoc
    1981 XS1100 Special Edition
    Alhambra, CA
  • randy
    • Dec 2003
    • 4521
    It's locked! Use your ignition key, look below the airbox you'll find the lock.
    • Athedra
      • Oct 2009
      • 221
      • Benoni, South Africa
      Well dont feel bad about the lock thing, took me weeks to figure out the seat is a bolt down and doesnt work with a key.
      Hope you came right
      Like I always say: " BLAME IT ON THE BEER "
      '79 XS1100 (2H9) named Bones
      1196 Big Bore
      4-1 Cowley exhaust
      750FD Conversion
      Echlin 54mm Racing Cones (Americanese = pods)
      Black Ebony Bottled glazed Tank (To be redone now)
      BMX footpegs
      Tank internally lined (Professionally this time)
      GSX400 Throttle bodies (Under serious investigation)
      Anti Sticky float bowl system
      • dontlikeoc
        • Nov 2009
        • 173
        • Alhambra, CA
        Thank you for your advice. The bike is in the shop for fuse box transplant now. I will come over on Tuesday to deal with the sidecover.
        Locking the side cover...a very strange concept. Kind of makes sense considering I once had lost a side cover of a GL1200 and had to pay $$$ for its replacement.
        dontlikeoc
        Alhambra, CA
          When you first try it, be aware that the key will only go in about half way, and push in gently on the bottom of the lock tab to take pressure off of the lock mechanism. That will save bending a key in case the lock hasn't been worked for a while.
            Hey Dontli,
            That cover conceals the toolkit and it also has a small compartment under there that allows you to keep your insurance papers, registration etc. I always put those items in a sandwich bag then put them in the small compartment.
            • jaimes-duran
              • Oct 2009
              • 44
              • Wake Forest, NC
              Like all these guys have stated, the left side cover is locked. If you look for it it is hard to spot but you'll find it near the bottom left side of the cover. Your key only goes in a little only the tip. It's actually neat that this locks because this way since the battery can only come out one way it can't be stolen! Also it has the compartment mentioned by the others. Also if you look on the same side of the bike near the rear shock there is another locking mechanism to lock your helment on the bike.
              • TomRodgers
                • Jun 2008
                • 492
                • La Porte Indiana
                BEEEEEEE GENTLE!!!!!!!!!
                I laminated my papers. dont want the fuzz thinking i have a dime bag of goodies!!!
                '81H (my first XS ) "Grey Ghost"
                4:1 Jardine w/ headerwrap
                Windjammer(wiring issues)
                New paint/brakes to come!!
                '80G FrankenBike (parts bike)
                '80G to fix "BlackSunshine"
                Stock Pilots/125 mains
                Pod filters; 4:1 Kerker??
                SS Brake lines w/ new M/C's
                LED Brake Lite
                Needs paint....
                • jjwaller
                  • 242
                  • Gautier, MS
                  Be careful with that. In many places laminating registrations is illegal. They won't count if laminated. Might check it out, just to be on the safe side.
                  Hard to believe, but true.
                  John
                  '81 CB900C ( 10 Speed)
                  '78 CB750F ( The F)
                  '76 CB400F ( The Elf)
                  New '82 Honda MB5 Ring Ding
                  Then: '76 CB550K
                  '78 CB750F
                  '84 VF1100S
                  And still Looking!
                  • cywelchjr
                    XS-XJ Super Guru(Deceased)
                    • 4450
                    • Sacramento, CA
                    Here is Cali their now recommending that you don't keep the papers in the vehicle any more but rather carry a copy in your wallet (has to do with concerns over identity theft). You don't have to carry the original with you here, just a copy is fine. That said, I keep my reg papers in the locked pocket of the fairing, and the insurance card in my wallet (pretty much anybody other than me that rides it will have done so over my dead body). I don't ask to ride someone else's bike, and pretty much would not let someone ride mine (not totally true, if I really trusted someone I would likely let them, but only for an around the block or such thing). To me, your bike is just too personal, especially after spending many hours getting the bars and controls set to where I like them, I would not feel comfortable with someone else's settings and I doubt they would be comfortable with mine.
