Anyone tried these?
  • xs11head
    • 29
    • St Louis, MO
    Anyone tried these?
    I came across this product on the internet and wonder if they actually work for tire balance. innovativebalancing.com Has anyone tried these?
    1978 XS1100E, superbike bars, 4 into 1 Kerker, k&n, repaired trans.
  • XJOK2PLAY
    • 2099
    • Skiatook, Ok.
    No link to see what you're talking about...
    2011 Kaw Concours 14 ABS
    • xs11head
      • 29
      • St Louis, MO
      • XJOK2PLAY
        • 2099
        • Skiatook, Ok.
        Yes...
        A thread search should show where they've been recently discussed.
        Kinda like a tire or an oil thread... opinions vary.
        • XSokieSPECIAL
          • Jun 2009
          • 1631
          • Tulsa, OK
          I've heard it go both ways with those beads. I personally wouldn't go that way.
          The dealer here only charges me $4 to balance my wheel if I carry it in.
          • Ivan
            • Jul 2008
            • 2524
            • Hutchinson KS
            I've heard that snake oil works for balancing wheels too.
            Ich habe dich nicht gefragt.
            • oseaghdha
              • 1075
              • N43.02.5,W88.14.2
              Magic Beans.
              XS1100SF
              XS1100F
              • 81xsproject
                • 3185
                • Fortuna, CA
                I DID try them, and no they don't.
                '81 XS1100 SH
                Sep. 12th 2015
                RIP
                • Ivan
                  • Jul 2008
                  • 2524
                  • Hutchinson KS
                  The dynabeads, magic beans or the snake oil?
                  • Elevener
                    • 608
                    • small town in TEXAS
                    I did try them, they do work.
                    In my truck and motorcycle.
                    Trapped in time. Surrounded by evil. Low on gas.
                    1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
                    • Dragon Tamer
                      XStremely XSive(Deceased)
                      • Sep 2006
                      • 426
                      • Half way between Chili and Winter Wisconsin.
                      I replaced the front tire on my Maxim a couple of months ago and picked up a rythmic vibration. Installed the magic bean reptile oil beads and there was no perceptable difference. Removed the little critters with a shop vac and took the reinstalled tire and rim to a local shop, they balanced the assembly in about four minutes for $5 and the problem went away.
                      They said it only took a 1/4oz weight to cure the problem so it wasn't all that bad but the beads would not handle it or even make a change that my highly trained engineering type body (which may need a tuneup) could detect.
                      The Old Tamer
                      _________________________
                      1979 XS1100SF (The Fire Dragon)
                      1982 650 Maxim (The Little Dragon)
                      another '82 650 Maxim (Parts Dragon)
                      1981 XS1100SH (The Black Dragon)
                      If there are more than three bolts holding it on there, it is most likely a very important part!
                      • Ivan
                        • Jul 2008
                        • 2524
                        • Hutchinson KS
                        Once again I have to ask, the dynabeads, magic beans or the snake oil?
                        • TomRodgers
                          • Jun 2008
                          • 492
                          • La Porte Indiana
                          I have used the beads in my truck tires ( 44" SuperSwampers ) that are biased ply. that much rubber is hard to balance. works well at speeds over 25 mph...between 15 and 25 it bounces you like a superball in a coffee can falling down a mountain... but then it smoothes out like a bikini models a$$ above 25. about 3 pounds in each tire.
                          '81H (my first XS ) "Grey Ghost"
                          4:1 Jardine w/ headerwrap
                          Windjammer(wiring issues)
                          New paint/brakes to come!!
                          '80G FrankenBike (parts bike)
                          '80G to fix "BlackSunshine"
                          Stock Pilots/125 mains
                          Pod filters; 4:1 Kerker??
                          SS Brake lines w/ new M/C's
                          LED Brake Lite
                          Needs paint....
                          • barberad
                            • 416
                            • the 45th state
                            Originally posted by TomRodgers
                            I'm sorry Tom...did you say something? All i could do is follow the bouncing
                            Current Rides: '82 XJ w/Jardine 4-1's, GIVI flyscreen, '97 Triumph Trophy 1200
                            Former Rides: '71 CB350, '78 400 Hawk, '75 CB550/4;
                            while in Japan: '86 KLR250, '86 VT250Z, '86 XL600R, '82 CB450(Hawk II), '96 750 Nighthawk, '96 BMW F650
                            • TomRodgers
                              • Jun 2008
                              • 492
                              • La Porte Indiana
                              ah...no i didnt....my plan to hypnotize all channel 11'ers is starting to work. soon you all will deliver your fully completed and customized XS1100's to me... hehehehahahahhahaha
                              LED Brake Lite
                              Needs paint....
