Weird Vibration
    OK... Clips are the simple slide on C clamp that clips on the inside of the yoke. I couldn't find my digital caliper, but my english one with my conversion said:
    End cap to end cap installed = 2.308" (58.6232mm)
    Cap diameter = 0.787" (19.9898mm)
    Yoke width minus the caps = 2.085" (52.959mm)
    All four sides are equal.
    • XS1100 Newbie
      • Jun 2009
      • 1106
      • Battle Ground, Washington
      Thanks Tod. I'll get to work on it.
      1980 XS1100LG Midnight
      1991 Honda CBR1000F Hurricane
      A cold beer and another one!
        • 7766
        I remember something about an early Datsun, 1200 or 510, using the same U-joints.....
        • Steptoe
          • 175
          • Thabeban,Bundaberg QLD , Australia
          uni joints
          STOP,,, DON,T DO IT,
          A universal joint out of a toyota forklift will fit straight in,,
          will more than likely be in stock on a shelf in a bearing shop..
          take your old one in for measurement and might cost you $20 or $ 30
          never ride faster than your gaurdian angel
          can fly
          1981 rh 5N5
          MIDNIGHTSPECIAL
          1188cc
          4 into 1 pipes with a transac muffler,
          as the motorcycling gods intended everything else stock std
          http://s856.photobucket.com/home/steptoexs11
          http://steptoexs11.webs.com/
          http://www.youtube.com/my_videos?feature=mhum
          1982 vf750 sabre
          • randy
            • Dec 2003
            • 4521
            Sounds like you've done it. What model forklift? Got a part # for the joint?
            • Steptoe
              • 175
              your right
              g,day Randy, yep was a while ago now, can,t remember, I took mine in with me, they measured it and the rest is history.
              20 mm caps / 40 mm across, [inside the yoke ] clips on the inside
              can fly
              1981 rh 5N5
              MIDNIGHTSPECIAL
              1188cc
              1982 vf750 sabre
              • XS1100 Newbie
                • Jun 2009
                • 1106
                Good news. Forklift sounds good. I am continuing my search. One from the auto parts store may be less expensive. Was the one from the forklift greasable? I think i may have found one, but i am going down to Napa, and going to measure it myself. It is off an early Datsu, and Toyota.
                • Steptoe
                  • 175
                  uni joint
                  hey fella's,, the joint I bought was NOT greasable, [it been a while since I've seen an auto joint that is, most of them now are sealed, " SELF GREASING" ]
                  I purchased mine from CBC bearings, we also have SKF shops,[ industrial heavy machinery type stockists ] our local auto stores don't stock this type of thing.
                  hope this helps
                  can fly
                  1981 rh 5N5
                  MIDNIGHTSPECIAL
                  1188cc
                  1982 vf750 sabre
                  • b.walker5
                    • Feb 2009
                    • 1745
                    • Invercargill, New Zealand
                    Possible replacement
                    Based on Tod's measurements, this looks fairly close.
                    Driveshaft Parts has a lot of drive shaft parts in stock, including u joints, high speed cv parts and more. For high-quality drive shaft parts and CV joints. Contact us!
                    Slightly shorter across the caps but the cap size is right.
                    • b.walker5
                      • Feb 2009
                      • 1745
                      neapco.com also have a listing thats pretty damm close to Tod's dimensions. Part number is 1-1011 and lists as being fitted to all Toyota 1200's from 68 to 79. Toyota part number is 04371-10010. Size is .788" x 2.260"
                      Koyo part number is T2957.
                      • Steptoe
                        • 175
                        Very very wrong
                        # 1 THERE ARE NO CLIP SLOTS
                        # 2 THAT UNIVERSAL IS FOR BOLT ON YOKE CAPS
                        go back to my post with 20 40 measurements, you won't go wrong
                        can fly
                        1981 rh 5N5
                        MIDNIGHTSPECIAL
                        1188cc
                        1982 vf750 sabre
                        • b.walker5
                          • Feb 2009
                          • 1745
                          Ok, where do you get the 40mm from. Tod's measurements would tend to suggest around 58mm cap to cap and 53mm without caps, which is pretty much spot on with the details given on the supplier websites. I'm not doubting you about the clips as i've never had one out and dont know with any certainty but I have dealt with plenty of Holden U joints over the years and the clips on them are at the ends of the caps, so I assumed these would be similair.
                          and you must be looking at the wrong joint on the sites as the ones I identified are not for bolt on yokes, theyre designed to be held in place by clips at the ends. Check the Neapco site, it shows the joint and clips in the application pictures.
                            There aren't any slots in the yoke to have the clips at the end. The caps are held by slots in the caps themselves and a c-clip holding them on the inside of the yoke.
                            I didn't understand the 40mm length either that steptoe showed... BUT... is the width really that critical? If it was longer from cap to cap and the caps stuck out a bit from the yoke, but you could still clip the inside.. why would that matter? There's room in the driveshaft housing so space isn't critical. And in that aspect, if it was shorter cap to cap and the caps were actually tucked down into the yoke.. as long as you could get that clip on them, would it matter?
                            The only thing critical I see... would be to where the caps were all the way down (Or really close to being that way) on the U-joint body when the clips were installed. If the shaft of the U-joint doesn't go into the end of the cap and hits the roller bearings somewhere in the middle, it's too much leverage against the roller bearings and it will cause premature wearing of the ends of the U-joint body and your needle bearings.
                            That being said... I'm not sure how you could go clear down to a 40mm width? Not saying it can't, but that's a pretty big difference.
                            • 79XS11F
                              • Jul 2006
                              • 3563
                              • Ottawa, Ont. Canada
                              As long lived as those U joints are, I neven could figure out why they were a sealed unit. I will guess that Yamaha figured that they would be too much trouble to get access to for regular greasing.
                              Rob
                              KEEP THE RUBBER SIDE DOWN
                              1978 XS1100E Modified
                              1978 XS500E
                              1979 XS1100F Restored
                              1981 Suzuki GS1100
                              1983 Suzuki GS750S Katana
                              1983 Honda CB900 Custom
                                And the shaft would wobble side to side in the caps and would cause the driveline to be off center and wobble/vibrate.
