exhaust
  • mack
    • 2411
    • Ontario, Canada
    exhaust
    Just read about the exhausts. I want to keep this as close to original appearance as possible. Apparently, Mac & Jardine both both supply a 4-2 style.(never heard of either one) Which of each brand will allow for oil changes w/o removal. And does either one allow you to keep your center stand? Also links would be great.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • Guy_b_g
    • May 2007
    • 790
    • Beverly Hills, Florida
    Jardine no longer makes exhausts for the XS11. You would have to find a used one, oil changes and center stand both good with the Jardines..not familiar enough with Mac to give a good answer.
    Guy
    '78E
    • XSokieSPECIAL
      • Jun 2009
      • 1631
      • Tulsa, OK
      This Jardine system just sold on ebay REALLY CHEAP. I wanted it but didn't get back to ebay in time or I would sell you this one or the mack on my bike. depending on which I wanted.
      Both allow easy oil filter access.
      Click
      http://cgi.ebay.com/XS1100-STANDARD-...item2c517310a6
      This is my Mack.
      • mack
        • 2411
        • Ontario, Canada
        looks like you got to keep the foot pegs as well. Did you have to re- jet your carbs?
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
        • XSokieSPECIAL
          • Jun 2009
          • 1631
          • Tulsa, OK
          No. Actually I am running 79 carbs on my 80 and with that setup it was running a bit rich for some reason anyway.
          I've since even put straight through baffles on and that helped MY situation.
          I bought another brake pedal becouse I was told I would need the clearance there but didn't. So if you end up with that problem when YOU change let me know if I can help you out.
            Mac muffler
            Will the MAC 4 into 2 readily accept a muffler exchange, such as the one pictured?
