It's not perfect....
  • It's not perfect....
    But I'll use it. I figure the only ones staring at this area of my tank hard enough to notice the imperfections are hot, lustful U of Texas coeds and they aren't looking at the tank at all.
    Meanwhile, back in the real world, here's my fix....
    The way it was:
    What I did (several layers of bondo over several days)....
    How it looks now....
    The dents pushed out the bottom of the tank a bit, as you can see if you look closely, but I'm thinking the seat will camouflage that. The rest of the patch actually is more rounded that the light lets it appear in the picture.
    I will totally use this tank now.
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
    paint
    Great job. Looks like it will all cover pretty well with the seat etc. The blue you used is great.
    Gary
    Gary King
    79 xs 1100 special/ standard front end
    bobbed with love.
      Thanks, Gary. I really like that shade of blue too. I can't get my camera so show the texture. It is a metal flake paint with big metal flakes. It really sparkles in sunlight, but I can't get that to show up on film.
      1969 Yamaha DT1B
        A real work of art with the bondo. I hope it does hold because it is a pretty deep repair.
          I have some concerns about its durability as well, Skids. But I already had the Bondo and the paint and my alternative was to toss the tank. I really had nothing to lose and potentially a nice tank to gain. That's why I did six thin layers of Bondo and let them cure well between coats. The rest of the tank is solid and it already was lined.
          Only time will tell.
          Patrick
          1969 Yamaha DT1B
            My standard tank (81) was in better shape internally than either of my other tanks... But had a HUGE dent in the right side of it where the PO layed it down. i couldnt get the dent out, so instead of going that deep with Bondo, i tack welded some studs all around to give it something to grab onto. I used fiberglass mesh as well. seems to be holding up rather well. From hot days of 100+ degrees with high humidity, to lows of 10- . Been that way for a year now and no issues as of yet....
            4:1 Jardine w/ headerwrap
            Windjammer(wiring issues)
            New paint/brakes to come!!
            '80G FrankenBike (parts bike)
            '80G to fix "BlackSunshine"
            Stock Pilots/125 mains
            Pod filters; 4:1 Kerker??
            SS Brake lines w/ new M/C's
            LED Brake Lite
            Needs paint....
              Gives me sympathy pains to think of what may have caused those dents...
              Could you not have used those to grab on to and pull that dent out some?
                i tried. but was leary that my puller would puncture the tank elswhere....snapped two studs trying to pull it out.... they just dont make steel the way they used to. this stuff is tuff!!
                LED Brake Lite
                Needs paint....
                  Turned out nice! Bondo can be wonderful stuff.....
                  If you prepped it good (roughed up the metal with 24 or 36 grit discs), you'll have zero worries about it coming out, unless of course you try to duplicate the original dents.... but that'll be the least of your problems!
                  '78E original owner
                    I know this is off topic but I have no words to describe how much I like TomRodgers activar & how I totally loose all interest in the post - Sorry just had to mention it (by the way never change it) - Dan
                    '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
                    1179 big bore kit, 80SG motor
                    Rebuilt head, valves
                    TC Bros Forward Controls (Brass Pegs)
                    Tkat Fork Brace
                    T.C. Spade Fuse Box
                    Dyna Coils & wires
                    Mikesxs shocks,controls,& bars (special)
                    ISO grips with stelleto ends
                    4 into 1 black Bassani exhaust
                    Bridgestone Spitfires
                    Tuned by Tinman905
                    & a will to keep it.
                      ...First thing I noticed as well, HAHAHA!
                      The paint looks pretty sweet at a close second
                      Josh Yoquelet -- I'm having dreams of my XS
                      '79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
                      '79 XS11SF "bobber"- Rotted in a pine tree for 10 years
                      '81 Air forks w/23,000 miles
                      New steering head races and bearings
                      '78/'79 standard wire harness
                      Drag bars, w/Mikes controls
                      T.C.'s fuse block
                      PNM Coils
                      7mm Dyna Wires
                      NGK Resistor Caps
                      Custom 1" clutch and 9/16" MC
                      http://xs11bobber.tripod.com
                        Yep, I know whatcha mean...
                        • #13
                          Now THATS what I'm talkin' about! (I knew I saw one in motion before)
                          • #14
                            I hate to ruin it for everyone but.................. the right one is bigger.
                            Famous Myspace quote:
                            • #15
                              I LIKE IT!
                              Deny
