inside the clutch cover there is a little tab there to hold the cable in place... how important is that and how do you get it back on if it falls... how was it held on (strong adheasive??)
clutch cover
clutch cover
Chris
twitter.com/thechrisdemon -- instagram.com/chrisdemon
2012 HD FXDC -- bone stock... for now...
1980 XS1100 Special --
under restoration for brother
2010 HD XL1200 -- good riddance...
1981 KZ650 CSR -- Found a good/new Home
1980 CX500 -- livin' it up in FL
Tags: None -
BY little tab I assume you are talking about the tab on the cable holder that bends down to keep the cable in place, right? I've always considered that part to be a bit of overengineering. Most bikes I've worked on don't have it because the tension on the clutch cable itself and the notch on the end of the cable will hold the end in place. If the cable isn't popping out I wouldn't worry about it.
PatrickThe glorious rays of the rising sun exist only to create shadows in which doom may hide.
XS11F (Incubus, daily rider)
1969 Yamaha DT1B
Five other bikes whose names do not begin with "Y" -
It's actually a metal piece, welded (?) to the throwout arm. It's not very strong to begin with, so I would think it would be fine to not have anything there at all. However, my paranoid mind would probably convince me to strap a zip-tie or something on there anyway...1980 XS850SG - Sold
-H. FordComment
thats what i figured but i wanted to ask 1st otherwise it proly woulda been crucial. i didnt notice it on my kz. it suprisingly was still under the cover. maybe ill just put a tack weld on it thanks guysChris
I'm sure Andreas will have about a hundred of those actuator arms laying around. You might contact him and see if he'll sell you that if you want to have a piece of mind about it.
