Part power drop out
    Part power drop out
    I tried to burn my bike down last fall. With all the things life throws at you, I'm only just getting to sort it out.
    It feels like I am losing one cylinder at about half throttle. I could be two, but I seriously don't think so. It won't accelerate up a hill and seems to be the same throttle position when it drops out. The drop out is independent of RPM.
    I replaced the number four carburetor. I used a body from a XS650. The carbs were dropped off and the work was done by a professional that I trust. I put everything together and rode the bike even though it was awful. Yesterday I took it to the shop where the work was done and had the carbs synched. That was a major improvement.
    My awful solder job on the advance wires is still holding. The vacuum line is plumbed to the #2 carb. I replaced the scorched wiring.
    Before the fire, this bike screamed. Now, it's a dog. Where do I go before I remove the carbs again?
  • xs11bobber
    • Jun 2009
    • 229
    • Cromwell, Indiana
    Check the voltage of the hot wires with a DMM (all reds, red/yellows, red/whites, orange, and grey). Is all power there when at idle? I'm thinking you may have the issue consistantly, but you just notice it the most or a lot more.
    If electrical checks out, then maybe it's a fuel problem. Maybe a shot diaphragm? Carbs are thoroughly clean? Since you mention that #4 was replaced, I'm assuming they were torn down. Check ALL jets(Fuel and Air) for clear passages. Could be a multitude of things all trying to be diagnosed at the same time. HTH
    Josh Yoquelet -- I'm having dreams of my XS
    '79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
    '79 XS11SF "bobber"- Rotted in a pine tree for 10 years
    '81 Air forks w/23,000 miles
    New steering head races and bearings
    '78/'79 standard wire harness
    Drag bars, w/Mikes controls
    T.C.'s fuse block
    PNM Coils
    7mm Dyna Wires
    NGK Resistor Caps
    Custom 1" clutch and 9/16" MC
    http://xs11bobber.tripod.com
      Since I made the post, I pulled the spark plugs. #4 has a white electrode. The other three are light gray. I will try to raise the float height tomorrow and see if that helps. I'm suspicious that it might be running out of fuel when I open the throttle.
      The #4 carburetor body was replaced. All of the parts were interchanged from the original as the donor was from an XS650.
      It runs fine if I don't open the throttle beyond half way. I don't expect it's electrical. I'd like it to be.
        Sounds like they are al running a bit lean with four being the worst. Do you have access to a colortune? Perhaps it would help to look in and see what is happening at those throttle positions.
