Bottom engine casing replacement
  • strom
    • 1577
    • Slovenia, EU
    If someone wanted to replace just the bottom half of the engine casing... and use 2h9 top and 5k7 bottom... yay or nay?
    Bearings and internals would remain 2h9.
    3
    Yep.
    33.33%
    1
    Nope.
    66.67%
    2
  • mro
    • 4276
    • Hayward, California
    Problem is with fitting the bearings.
    Limited bearing sizes available.
    Could get lucky and one of the four sizes available will work.
    Only plasti-gauge can tell
    mro
    • red bandit
      • 970
      • central michigan
      They are machined as a pair. I wouldn't recommend mixing any combination. Same w/ the head and cam bearing caps.
      79 SF parts bike.
        • 7818
        IF you can shave about .05mm from the case, and line bore the crank and trans shafts, it MAY work. problem is the cost of the machine work to make sure it's correct. IF you are lucky it may work well for a while.
        The ONLY way to know is measure EVERYTHING once you dry fit the two cases together.
        • 79XS11F
          • 3563
          • Ottawa, Ont. Canada
          Don't mix them up unless it's the ONLY option available to you. At this point in time there are lots of engines around so if you need a new lower case, Buy a engine, use the cases and keep the extra parts for another day.
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
