XS-100 electrical fault
  • mbancro
    • Oct 2009
    • 2
    hi, i just bought J reg XS-100, it runs but i have no indicators, head lights orback break lights and no dash lights working...
    can someone please help with my problem???
  • tw1980
    • Apr 2009
    • 662
    • Bend OR
    I assume you meant xs1100 right?I'd start out checking fuses and the fuse holders.Then plugs for oxidation and bad connections.Then ignition switch.Welcome to xs11.com.
    Terry
    1980 special (Phyllis)
    • wingnut
      • 695
      • NC
      Be willing to bet you have a fuse/fuse box problem. Either the fuse is blown or the connection to the fuse is bad. Check the fuse with a Ohm meter, Your eye ball is not good enough. Also very carefully clean the little tangs that hold the fuses. If you bust it I have replacements. Also +1 on the grounds. They have got to be good and clean or all sorts or weird stuff happens
      wingnut
      81 SH (Daily Ride)
      81 XS 400
      Thomas Jefferson
      • mbancro
        • Oct 2009
        • 2
        ok thanks i will check the fuss/fuse box to see if thats the problem
          Post you location and you may find an XS owner willing to ride out and help for a cold beverage... My question is the Tachometer working? If not, time to start at the beginning of the charging system. If it IS working, I would look at the fuse block, and then go to connections behind it.
          Cleaning ALL the connections, and using dielectric grease on the "hot" connections, will help. I use NO-OX or anti-seize on ALL the ground bolts, after CLEANING everything.
