I have a 1980 LG Midnight Special with a first gear problem. And yes I am also searching the site. All other gears work fine but if I put it into first it will lock up and will then not come out of first with the bike running. I have to turn off the bike and rock it back and forth and take it out of first by hand. I have ridden it awhile starting off in second but do at times without thinking, go down into first. It does seem to go in and out of first when the bike is not running.
It is time to fix the problem. Some ideas please on what is causing the problem? I am hoping it is something that could be done with the engine in the bike or if not then with the engine out. But, hopefully we do not have to split the case. I have a sized (from rust) '81 Engine that I have taken all the transmission parts out of for parts, if needed. To remove all the parts I had to split the case and I am hoping I do not have to do that again. It is definitely easier knowing it does not have to go back together again.
All suggestions welcome and hopefully someone out there has had a similar problem.
