Jardine 4-2 Exhaust
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    Jardine 4-2 Exhaust
    Are the Jardine Spaghetti exhaust systems supposed to be so hard to take off and on? I replaced my engine this weekend (job still to be completed in part because of the exhaust and in part because of my stupidity in taking off the airbox) and I literally had to take each downtube out of it's collector before I could get the rest of the system off. And now it looks like I have to get them back in, and they seem to be just a friction fit into there. Is this really the way they are supposed to be? It took me over 2 hours just to get the frackin things off, and I think it's going to take longer to get them back on, and I'm worried about leaks as well.
    Any suggestions or ideas? This includes all the way up to "your an idiot, you should have done it {proper procedure} instead of what you did".
    Also if I didn't do it too wrong, what do I do to minimize leakage at the joints?
    Thanks.
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    I took the same set off my 79 sf . They came off with no problem left side and right side .I didn't have to break it down to each tube.
    BDF Special
    • Cobia
      • Jul 2007
      • 1587
      • Palm Beach County, Fl
      Jardine 4 x 2, my experience
      Cy,
      I encountered the same situation both on teardown and re-installation. I didn't want to take them apart at the crossover either. What did the trick for me was:
      1. Remove the sidestand and extend the centerstand
      2. Elevate the front wheel about 1' off the cround (I used an engine hoist, and took the tank off to tie in to the frame)
      3. When installing, you have to turn the whole assembly diagonally to get it past the centerstand then position it in place.
      4. You may need help holding the tailpipes up while you're aligning it in the exhaust ports
      5. Once aligned and the flanges are in the studs, you can bolt up the rear and tighten everything up.
      5. Re-install the sidestand
      One nice thing about raising the front up is that the exhaust gaskets don't fall out on their own, so you don't have to fight them.
      Even so, the one pipe that cuts diagonally accross still came off the collector. If high temp rtv doesn't seal it (I think it will) I'll just put a clamp on it somehow.
      Good luck.
      OOHHhhh, don't forget to put that diagonal pipe in first if it's off the collector. DAMHIK
      1980G Standard, Restored
      Kerker 4 - 1
      850 Rear End Mod
      Automatic CCT
      1980GH Special, Restored
      '82 XJ1100 (Sold)
