Whats the general opinion on having some of the exterior covers chromed. Is there really a problem with heat retention. If this is the case which parts should absolutely not be chromed?
chrome
chrome
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
If it's that big of a worry, you could just get them fake chrome high-temp ceramic coated. Prices are close, around here anywayJosh Yoquelet -- I'm having dreams of my XS
'79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
'79 XS11SF "bobber"- Rotted in a pine tree for 10 years
'81 Air forks w/23,000 miles
New steering head races and bearings
'78/'79 standard wire harness
Drag bars, w/Mikes controls
T.C.'s fuse block
PNM Coils
7mm Dyna Wires
NGK Resistor Caps
Custom 1" clutch and 9/16" MC
http://xs11bobber.tripod.comComment
Or, just polish the aluminum. I've seen a few of the bikes on this site look REALLY shiny after a nice polishing job!1980 XS850SG - Sold
-H. FordComment
Chroming is not a problem, however it takes a chrome shop who knows how to chrome aluminum and make it last. This bike has run about 30K over 5 years and no significant problems. A few bubbles on the valve cover due to heat, but thats it.
[IMG][/IMG]
1980sg-Stocker-- Sold
1980sg- Cruise Missile- Sold to RODS454
1990 ATK 604- Ditch Digger
2005 BMW K1200S- Killer Bee
2005 Suzuki GSX-R 1000- trackbikeComment
Been there, done that. No issues (other than cost! Chrome sure isn't as cheap as it used to be!) except if you send in any parts that have steel bushings/parts in them. If the plater has any problem with a part, he may need to strip it more than once. The solution they use to take plating off of aluminum eats steel. Most steel parts can stand 1-2 trips though but more than that and you can have problems.
I did all the polished stuff on my XS650 back in the early 70s, and the guy had problems with the right side primary cover. Aluminum castings are notorious for having 'internal' flaws in the metal that can make plating hard. The guy did this cover 4-5 times before he was happy with the results. Looked great when I got it back. But when I went to install it, the kickstarter shaft bushing was gone! The solution had ate it! As this wasn't available as a separate part (only came with the cover), I ended up having to have one made out of bronze. By the way, bronze parts aren't affected and are safe to dip.
So I'd recommend pulling any steel bits off if possible, and it not, taking some careful measurements prior to plating in case you need to have one made.
'78E original ownerFast, Cheap, Reliable... Pick any two
Strip the clear coat off and try the polishing trick first, you might very well like what you see. I stripped the clear coat off of every cover I could get to and did the fork tubes also. A mini-power ball and some small cotton wheels on a drill with some Simichrome make quick work of the task. Upkeep isn't hard at all, but then again I like to polish up my bike.When a 10 isn't enough, get a 11. 80g HardbaggerComment
if you want the facts, they have been posted.
But you asked for an opinion.
My opinion is there's a hundred better things to spend money on for an XS11 than chroming the aluminum parts.
Betcha buying a can of Mother's aluminum polish, a box of rags, two new tires and a set
of stainless brake hoses would cost less than getting your aluminum parts chromed over.Fred Hill, S'toon
"The Flying Pumpkin"Comment
Yep, the aluminum has to be zincated prior to copper also. Aluminum cleaned and etched, then zincated, then hard copper flash, then bright copper for the shine and then bright nickel and finally chromium. Lots of prep work hence the rising costs.1979 XS1100SF.
"You know what makes me sad... YOU DO, Why dont we run over to mamby pamby land and get you some self confidence you jack wagon" Will go down as one of the great quotes LOLComment
I have the 4 side covers chrome. Alt, timing, clutch and shifter. I bought them second hand. Polished alum. is nice but it doesn't have the luster that chrome has.79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
79 SF parts bike.Comment
Thanx
Well my thoughts are, since I've got this big dude torn down anyway and plan on replacing everything that is suspect, I'm going to have a few $$ in it anyway. I'm at the age now that I would rather be spending 50 minutes riding the bike and 10 min polishing than 50 minutes polishing for every ten minutes of riding. I can't count the number of tubes of autosol, rags and bengay I've gone through over the years that I rode this thing. Until you see the engine sitting alone in the frame you really have no appreciation of how muscular this thing is. Stainless brake lines? Got any pictures? Don't worry about the rubber it will all be new and not just what hits the road, (so I don't).mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
The picture that dragxs11 posted has a rear SS line on it. They can be had in different colors too, if you want. I know when I get around to replacing my old OEM lines, I'll go with the black ones for my MNS. If you're going to spend $$ on your bike, the SS lines are a LOT more important than chrome. They are reported to greatly improve braking power, to the point that you have to re-learn how to stop after installing them.1980 XS850SG - Sold
-H. FordComment
To Chrome or Polish ??
Chrome be nice....
But when financial challenged ... Polished be nice too
If I had a choice, I'd prefer chrome. From a few feet away most will not notice much difference. Maintaining chrome is fast and easy. OTOH if you have a bench grinder and a palm sander it only cost about $20.00 plus your time to polish...
One good thing about polished aluminum is that you can “re-do” it over and over (Well sort of a good thing) and it will look like new agin and agin. Once a chrome piece gets bad it's bad. I talked to Bob at Merriam Cycles who restored the top 79 SF shortly after I got it, but he could not tell me when it had been done. I’m just guessing that the chrome must be around 10+ years old and still looks good. The other SF I just finished polishing weeks ago which originally started out as a carb cleaning then became an XSive adventure in paint and polish.
mroComment
[SIZE="4"]If I had a choice, I'd prefer chrome. From a few feet away most will not notice much difference. Maintaining chrome is fast and easy.
One good thing about polished aluminum is that you can “re-do” it over and over (Well sort of a good thing) and it will look like new again and again. Once a chrome piece gets bad it's bad.
mro
One other thing; any chromed aluminum will last pretty much in direct proportion to how well you keep it clean and dry. Chrome plating is porous, so any moisture you get on it can get to the underlying metal. Heavy waxing of plated surfaces helps. 99% of failures is because moisture got to the aluminum and it corrodes, lifting the plating. Ride in the rain, store the bike in a humid climate, and/or fail to keep it clean and it will go bad, sooner or later. NEVER put the bike away wet, as the cooling metal will draw any moisture right through the plating. The two examples shown here are both from dry climates, so YMMV.
One plater told me this.... 'Chromed aluminum is like a pretty teenaged callgirl; looks fabulous in the beginning, but the more you abuse her, the faster she ages...'.
'78E original ownerLast edited by crazy steve; 10-07-2009, 11:14 AM.Fast, Cheap, Reliable... Pick any two
