While reading a Chiltons motocycle repair of muti manufactors. I ran across mixing trans fluid and motor oil and then use this as the fork oil ? Any one try this?
mixing fluids and oils
Hi DB,
sure it'll work. The viscosity number of the mix will be the proportionate average of the oil & ATF numbers.
But besides the homebuilt cocktail having temperature resistance it don't need
and not having the anti-foaming properties it does need, it ain't an economical proposition.
A quart of engine oil plus a quart of ATF will cost you more than a 16oz jug of genuine fork oil
and then you have to label the rest of the mix and hope you can still find it next time.Fred Hill, S'toon
"The Flying Pumpkin"Comment
Back in my 'dune buggy' racing days, we used all kinds of oils in the shocks to get different damping rates (along with different damper orifice sizes)
If I remember correctly ATF is about a 7 weight. Not sure why they would mix it with oil, except maybe to get some lubrication.
The older Dexron fluids have very little lubrication ability. Type F has more lube, and Dexron III is very similar to Type F.
Transmission fluid is actually hydraulic fluid, not an oil as we normally think of it.Nice day, if it doesn't rain...
'05 ST1300
'83 502/502 Monte Carlo for sale/tradeComment
