Hi Guys,
I've been lurking here for the past month or so since I picked up an 1980 XS1100.
I spent the day striping down the bike and and sanding back some of the more corroded parts. During this phase I noticed that the PO has made a bit of a mess of the wiring.
I am planning on eventually running LED lights and getting rid of the sock switches so I was thinking of doing a bare bones rewire eg. Just enough to get the bike running.
What are the key components that need to be wired up for this? Are there any guides floating around for this kind of thing? Am I getting myself in too deep?
Any help would be great.
1980 XS1100
Sydney
1980 XS1100
Sydney
	 Are you saying that you cant get it to turn over yet you have backfiring from the carbs?, or are you saying that it wont start and has backfire? If it's the latter, given that you've rewired I would check the coil polarity, making sure that the feed for coil 1 + 4 (orange wire) is going to the correct coil, and ditto for 2 + 3 (grey wire). They only have two pickups and they have to be connected to the correct coils for them to fire.  If theyre the right way round then check the small wires from the pickups behind the left crankcase cover, they're notoroius for breaking down and you'll find a tech tip under repairs which covers it better than I can describe. If both of those things check out then you may be looking at things like incorrect ignition timing, incorrect valve timing or burnt valves. A compression test should highlight the last two and a timing light will sort the first one.
