Alternative to hacking the harness?
  • xs11bobber
    • Jun 2009
    • 229
    • Cromwell, Indiana
    So, I was going to take the left coil off and try swapping with one of the old stock coils I had my dad take off. When I started, I noticed that it didn't take much force to turn the nut from the bolt. Not even the weight of my arm. So I thought, hmmmmm, maybe they just aren't grounding and it's causing that 1 to appear bad. I re-tightened everything and now I get 135MV on the Orange. That's puts me about 7/8 of the way to 1 VOLT! Alright... making progress
    So does that mean my coil is really bad? I'm gonna do some experimenting with some jumpers or something and see what happens. I'll post results...
    Josh Yoquelet -- I'm having dreams of my XS
    '79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
    '79 XS11SF "bobber"- Rotted in a pine tree for 10 years
    '81 Air forks w/23,000 miles
    New steering head races and bearings
    '78/'79 standard wire harness
    Drag bars, w/Mikes controls
    T.C.'s fuse block
    PNM Coils
    7mm Dyna Wires
    NGK Resistor Caps
    Custom 1" clutch and 9/16" MC
    http://xs11bobber.tripod.com
      Where are you testing the "out" value for each coil? If you are sticking the test lead inside the sparkplug cap, you are measuring the coil plus the lead wire plus the potentially flakey connection between the lead wire plus the cap, plus the resistor in the cap. Be sure what you're measuring before you start throwing out perfectly good parts. (Hint - cut 1/4" off of the lead wire, reattach the cap, and retest).
      • xs11bobber
        • Jun 2009
        • 229
        • Cromwell, Indiana
        If you read closely in the earlier posts, I think I said it. I haven't been testing plug caps or wires, because they're brand new. I'm testing at the male spade ends molded into the new PNM coils.
        I was getting intermitent spark. I've somehow changed that to just spark on 2&3. I was doing Randy's TCI test and noted 35MV on the Orange wire at the TCI so I knew I had a problem because Grey and Orange at the TCI should read the same.
        Red/White at the coils is 11.72V on both sides. I'm testing the PNM(Parts N' More - GL1100 OEM Replacement) coils on my dad's E so I have the short leads from my old stock(SF) coils attached to the new coils. Red/Whites at the coil spade connector are 9.54V and 9.76V, so I know I'm loosing 2V between the Red/White double bullet connector and the female spades I crimped on to fit the new coils. On the right coil (Grey wire) I'm getting 9.87V, but ont he left coil (Orange wire) I'm getting 135MV.
        So I don't know if this is a sign of a bad coil or what my problem is. I've swapped TCI's for others that tested fine on my SF and still spark on only 2&3 cylinders. I do think it's incredibly odd that with a tighter bolt I went from 34MV to 135MV.
        T.C.'s fuse block
        PNM Coils
        7mm Dyna Wires
        NGK Resistor Caps
        • xs11bobber
          • Jun 2009
          • 229
          • Cromwell, Indiana
          Here's what I did...
          ...And I'm testing at the blue connectors
          T.C.'s fuse block
          PNM Coils
          7mm Dyna Wires
          NGK Resistor Caps
          • xs11bobber
            • Jun 2009
            • 229
            • Cromwell, Indiana
            Still needing some help...
            So I removed the PNM coils and tested the primary resistance and it was 2.5 Ohms. I then measured the stock coils that were removed from the bike and they were at 1.5 and 1.6 for the primary resistance. I went ahead and reinstalled the stock coils after trimming back the wires 1/4". I then reattached the ballast resistor and measured all voltages. All were around 11.72V EXCEPT the ORANGE WIRE.
            So this thing needs to get power from somewhere. Where do I start?
            T.C.'s fuse block
            PNM Coils
            7mm Dyna Wires
            NGK Resistor Caps
              The orange wire runs from the TCI to the 1+4 coil. Check for voltage back at the TCI. ??
              • xs11bobber
                • Jun 2009
                • 229
                • Cromwell, Indiana
                Suddenly, out of nowhere, I have 11V on orange and grey. WTF!
                Tested at the TCI and then at the coils. Twas the same.
                T.C.'s fuse block
                PNM Coils
                7mm Dyna Wires
                NGK Resistor Caps
                • xs11bobber
                  • Jun 2009
                  • 229
                  • Cromwell, Indiana
                  Is this common of the pick-up wire fix?
                  T.C.'s fuse block
                  PNM Coils
                  7mm Dyna Wires
                  NGK Resistor Caps
                    Hey Josh,
                    Been out of town for this past week.
                    Okay, with your new DMM, check the voltage ON the coil where the Orange wire would contact with it. Also check the resistance thru both ends of the Orange wire....from the coil end to the TCI end, should be very low value, and measure the same for the gray for comparison.
                    You put the OLD coils in, and got the full voltage on the Orange wire at the TCI. Remember, the Orange wire is just continuing the power from the RED/WHITE wire that goes THRU the coil.
                    So...put the PNM coils or at least the suspect coil back in, and test the power where the Orange wire connects to the coil and you'll probably find that it'll also be low...in the MV range...which would indicate that that particular coil is fried/damaged.
                    When you first tested your OEM coils, you found the same low MV reading on the Orange wire. Check the orange wire as described above, you may have flaky connections/terminals on the ends of the Orange wire.
