XS Gods...help if you can....
  • TomRodgers
    • Jun 2008
    • 492
    • La Porte Indiana
    Thors twins ('81 H and '80G for parts) have been joined by yet another 80G that has been sitting awhile.. ( at least a year..i fear more..). After draining fluids, refilling....fixing vacuum lines(hooked up wrong) cranking idle screw back (was backed out ALLLLL the way) shooting a bit of juice (starting fluid), the beast fired up. rough. carbs will need to be cleaned and sync'd.. issue i have is electrical.... according to the wiring diagram for the front turn signals on the 80G's, the left turn signal is Dark Green and Blue. The right side is Brown and Blue. when i hooked up the left side DG and BL, the wires got hot enuf to melt the bullet end right off!!! the right side looks like the same color wires ( im slightly color blind, but SWMBO agreed with me...they look the same) but are in the stock wire harness....im guessing that all 4 signals must be hooked up in order to work properly? everything else seems to work okay..headlite hi/low, brake/running. the PO had rattle can painted the rear fender w/out removing it, and proceeded to paint the entire wiring assembly black!!! What a tool!!! any ideas as to the wiring?
    '81H (my first XS ) "Grey Ghost"
    4:1 Jardine w/ headerwrap
    Windjammer(wiring issues)
    New paint/brakes to come!!
    '80G FrankenBike (parts bike)
    '80G to fix "BlackSunshine"
    Stock Pilots/125 mains
    Pod filters; 4:1 Kerker??
    SS Brake lines w/ new M/C's
    LED Brake Lite
    Needs paint....
    The blue wire is for running lights on the Standards. There is a dual filament bulb. Use the dark green and ground at the stalk for signals, same with brown for the right side.
    • TomRodgers
      • Jun 2008
      • 492
      • La Porte Indiana
      Are all signals on XS's single filament? or are the newer models dual? I guess i was "overloading" the wiring then to get the melted wire!!!
      LED Brake Lite
      Needs paint....
      • clobe26
        • Aug 2009
        • 33
        • Los Angeles, CA
        What i did with my wiring was update it. I used "Switch Blade fuses" for certain wires & also used relays. Those should blow 1st before giving you a hot spaghetti effect.
        Clobe26's "Dummy-HardTail" Bobber (Ol' Betsy)
        • 18" Harley Apes
        • Dual Fat-bob Tanks with Moto Guzzi Petcocks
        • Polished Everything Aluminum
        • Blacked Out & Powdercoated
        • XS850 Front-End
        • Custom Made wiring
        • Hexed Out Bolts
        • Still in Progress.....
        Other bikes:
        1972 Moto Guzzi Ambassador
        1971 Moto Guzzi El Dorado
        1979 Honda CB750
        1974 Honda CB500
        1978 Yamaha XS1100?
        1979 Yamaha XS110SF
        2006 Kawasaki 636 ZX-6R
          Originally posted by TomRodgers
          - - - issue i have is electrical.... according to the wiring diagram for the front turn signals on the 80G's, the left turn signal is Dark Green and Blue. The right side is Brown and Blue. when i hooked up the left side DG and BL, the wires got hot enuf to melt the bullet end right off!!! the right side looks like the same color wires ( im slightly color blind, but SWMBO agreed with me...they look the same) but are in the stock wire harness....im guessing that all 4 signals must be hooked up in order to work properly? everything else seems to work okay..headlite hi/low, brake/running. the PO had rattle can painted the rear fender w/out removing it, and proceeded to paint the entire wiring assembly black!!! What a tool!!! any ideas as to the wiring?
          Hi Tom,
          the wires are coded B for Black and L for Blue.
          Clymer's wiring diagram shows the XS11H as having front signals with Dg & L wires + ground to the left and Br & L wires + ground to the right.
          This tells me that the front signals are both signal and running lights and thus should have twin filament bulbs in them.
          The rear signals have Dg or Br wires plus a B each that runs to a remote ground connection.
          The signal system on the '80 models is also complifexed by the 4-way hookup.
          A swipe with acetone should take the rattlecan paint off the rear wiring.
          And yeah, it's dark inside that headlight shell, eh?
          Mr Stupid mistook a black wire for a dark brown one in there to demonstrate that a transistorized flasher's pulse rate will not change even when hooked to a dead short.
          You get 3 pulses then the fuse blows. Damn fool did it twice to prove it.
          • TomRodgers
            • Jun 2008
            • 492
            • La Porte Indiana
            The PO had some rinky dink chrome signals bolted to where the regular side reflectors would go on the headlight ears. ill find out wether or not they are single or double filament... it threw me for a loop on the Clymer diagrams...cuz the new lights have two wires coming out of the hollow mounting bolt, (one ground one hot...so i thought) but with the mounting bolt being the ground, that complicates my situation. if they are single filament bulbs, just bypass the "running lites"...if they are dual, then what? thats what i tried and it melted the wires.....
            LED Brake Lite
            Needs paint....
            • TomRodgers
              • Jun 2008
              • 492
              • La Porte Indiana
              the rears i figured out...two of the wires had grounding bolt terminal ends on them, to be bolted to the frame. the others were the hot.... i hate electrical issues!!!!
              LED Brake Lite
              Needs paint....
              • TomRodgers
                • Jun 2008
                • 492
                • La Porte Indiana
                another issue....ive never sync'd carbs on my own before....looking into purchasing guages....found a set, but without adapters. what are the adaptors for? different bikes? i thought the hoses slipped onto the brass tubes off the intake boots.....any info would be greatly appreciated!!!!
                LED Brake Lite
                Needs paint....
