... okay, okay ... pick up the marbles
  • chinrest
    • Aug 2009
    • 29
    • Oly, Wa.
    If I had searched first like in the "nubies read this first" section recommends, I have found a couple of very firm citations to the effect that XS and XJ exhausts are pretty much interchangeable. So, I'll basically proceed with that assertion.
    Any insights to the contrary or tips about hidden aspects that experience (Wow, I didn't expect that ... kind of stuff) would be gratefully received.
    A fine running motor is a tune you just can't get out of your head.
    first yamaha --1980 XS1100G
  • barberad
    • 416
    • the 45th state
    Can't use a stock oil cooler on an xj1100 if you have jardine 4-1's . Don't know about the other 4-1's. My $.02.
    Dan
    Current Rides: '82 XJ w/Jardine 4-1's, GIVI flyscreen, '97 Triumph Trophy 1200
    Former Rides: '71 CB350, '78 400 Hawk, '75 CB550/4;
    while in Japan: '86 KLR250, '86 VT250Z, '86 XL600R, '82 CB450(Hawk II), '96 750 Nighthawk, '96 BMW F650
    • chinrest
      • Aug 2009
      • 29
      • Oly, Wa.
      pipes
      thanks, barberad. don't know if I'll run into that on the set I'm looking at or not. mine's an 80 xs G.
        I may be wrong and I'm uncertain as to which is which, but some of the motors had shorter exhaust studs in the head than others. I don't know if this makes a difference on the header collars or not??
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          Even if there is a difference, 6mm threaded studs are readily available at parts and hardware stores.
          Ich habe dich nicht gefragt.
            Unless they break off while trying to take the existing ones out of the head..
            • Ivan
              • Jul 2008
              • 2524
              • Hutchinson KS
              Easiest way to prevent that is to warm up the engine a bit, then take them off. The metal around the studs expands and looses the death grip on them. Also there are tools that make stud removal easy, they look like a socket with a washer on the front. There are rollers inside that grab the stud kind of like a sprag clutch. I think Lisle has them, and are pretty reasonable.
