gday. have recently been rebuilding an 81 xs1100r only to get it all back together and find it's not running very well at all. basically the problem is as follows:
there is significant pressure variation in the carbie maniflods - when i hooked up the synchoniser it was all over the place for all cylanders.
i took off the timing cover and had a look while it was running - the vaccum advance is also all over the place. unhooking this makes it run better. hooked up a timing light and it's firing perfectly.
the only thing i could put it down to was intake valves opening too early or closing to late.
i took off the cam cover etc and checked the timing marks - perfect.
got a light down the sparkplug hole and watched the piston move up and down relative to the valves closing / opening. it appears the intake valves are opening to early and closing too late. to me (very much a rookie) this would suggest insufficient valve clearance. the clearance is perfect to the specs in the manual i've got which states that the clearance should be .11-.15mm for models past 1980. i cannot find clearance specs specific for the "R" - also known as the sport and am thinking it might be different. can anyone tell me the correct clearance / suggest any other factors that may be causing it. have put a lot of work into this bike and now seem to be up that proverbial creek without a paddle. cheers.
