new plug wires or swap coils...???
  • yamahansolo
    • Aug 2007
    • 1113
    • jawga
    ok we have the big rally next weekend... my #3 wire zapped me the other night! i think they are old so i can buy new wires or take the coils off my xj and do away with my resistor.
    i did a search and couldn't find out if this was worth it or not. no time to get the mike's coils in and installed so i could just swap for now.
    the xs coils have about 25,000 miles on them and the xj's only have about 12,000. plus they look alot better. my caps on the xs were pretty corroded as well i swapped the xj ones that look brand new already.
    i thought it'd be a good temporary fix right?
    79 xs11 standard
    8mm msd wires
    tkat fork brace...
    Fox shocks...
    mikes650 front fender
    led's gallore...
    renthal bars
    gold valve emulators
    vmax tensioner
    Rifle fairing
    • 8893
    The XJ coils will work fine on the 79XS with removal of the ballast. Plug the 2 wires that lead to the ballast together. BTW, the harness leads to the coils have different plugs, so you'll have to rig up some jumper wires to connect them. I'm running the XJ coils on my 79F and they work fine.
    • xs11bobber
      • Jun 2009
      • 229
      • Cromwell, Indiana
      If you're doing the coil upgrade to the F anyway, you could cut those leads off the old coils and already have the bullet connectors on the one end that fit right into your harness. I kept mine from the old coils as part of the harness when I did the upgrade. HTH
      Josh Yoquelet -- I'm having dreams of my XS
      '79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
      '79 XS11SF "bobber"- Rotted in a pine tree for 10 years
      '81 Air forks w/23,000 miles
      New steering head races and bearings
      '78/'79 standard wire harness
      Drag bars, w/Mikes controls
      T.C.'s fuse block
      PNM Coils
      7mm Dyna Wires
      NGK Resistor Caps
      Custom 1" clutch and 9/16" MC
      http://xs11bobber.tripod.com
      • roccet
        • 102
        • bend oregon
        coil
        all i can say is i changed wires and aftermarket coils and the thing runs night and day difference and i had no problems before changing them out.. i just wanted to..
        1978 E XS1100 purchased for =$600.00
        crap load of time spent modifying it = Priceless
        My bike has the XS motor but can't really call it XS11
        (or at least it still looks like the XS motor)
        it has about 50% of the frame left from the XS bike
        • yamahansolo
          • Aug 2007
          • 1113
          • jawga
          i want to do the mikes coils but there is not ime to get them for the ralley i am sure. plus i had to email and ask them if they have morew than 1
          partsnmore shows only 1 in stock. there is a guy here on cl but he wants 40 bucks for it. he never used it.
          79 xs11 standard
          8mm msd wires
          tkat fork brace...
          Fox shocks...
          led's gallore...
          renthal bars
          vmax tensioner
          Rifle fairing
          • dbeardslee
            • Nov 2007
            • 4385
            • Maineville, OH
            Yamahan - The wires are pretty easy to change on the 78-80 style coils. I've gotten them out by just twisting them and pulling carefully on the wire (after removing the outer sheath). Cut a little slot in the tunnel with a dremel down relatively close to the pin where you can see the pin but it isn't completely uncovered. You want to be able to see the pin so you can tell when the new wires are on it, but leaving as much plastic around the pin as you can will give a more secure connection. A little WD-40 on the end of the new high tension wires will make them slip easily back into the tunnel and down onto the pin. Clean the WD off around the repair site with some acetone on a rag, and put some RTV over the holes. After it is fully cured put some duct tape over the repair, and put a large zip tie around the coil, and making contact with the high tension wires through the hole to hold the wires in place. The wires on the 81 style coils (3 ohm) are a genuine PITA to change. The wire that goes into the short tunnel is soldered in, and takes some very careful digging to uncover. My $.02.
            • yamahansolo
              • Aug 2007
              • 1113
              • jawga
              i might just swap to the xj and see if it runs good, and if so theni'll butcher the stock coils
              don't wanna miss this weekend because of something i did wrong!
              79 xs11 standard
              8mm msd wires
              tkat fork brace...
              Fox shocks...
              led's gallore...
              renthal bars
              vmax tensioner
              Rifle fairing
