here we go, 2 identical 11's side by side in the shed.
740 goes like a bat out of hell, 516 also goes like a bat out of hell----once you get the thing started----it has a very laboured wind over.
Have cleaned & polished the starter brushes, windings, commutator, planatries, & shined up all earth & contact points.
Still the same, soooo, swapped starters, 740 starts great, 516 not so, swapped start solonoids, 740 great, 516 same.
Soooo pulled the BATTERY out the 350 full alloy V8 [660 CCA], straight onto the starter cable, earthed directly off the starter, you guessed it, still the same, soooo swapped every thing over again with the big battery, 740 still turns over normally with all of 516's parts but 516 is getting closer to the scrap metal dealer by the second, almost forgot cables have been deleted from the equation as well.
Once 516 is running there are no issues, spark is strong, there are no charging probs, no missing, the only thing that could be a very long shot is the fact that there is no ballast resistor to give the coils their 6 volts to start,but if that was an issue, 740 would be the same--maybe--
Idea's will be great please, thankyou, ta
Have been working with these machines for 16 yrs, now am at an end with this problem, any idea's ?
