I have seen several members here making nifty solid mounts to replace the rubber isolators at the engine mounts. What are the R&D test results from these? Is the extra vibration noticeably bad? Is there any noticeable handling improvement?
solid engine isolators
Healthy is merely the slowest rate at which you can die
Some people will tell you that slow is good - and it may be, on some days - but I am here to tell you that fast is better. I’ve always believed this, in spite of the trouble it’s caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba….Hunter S. ThompsonTags: None -
careful what you wish for.........you might get it -
I fitted solid mounts and haven't noticed any vibrations at all. The bike fair glides along like a Swiss watch..
I did fit some bar end weights (from the XJR1300) just in case but I don't think it needed them anyway.'84 SportComment
Shapps, that's the FI that makes it SO smooth'81 XS1100 SH
Sep. 12th 2015
RIPComment
