How should I paint the final drive?
  • Clerek
    • Jun 2009
    • 144
    • Spokane, WA
    I want to paint the final drive, but don't want to cover up the breather hole. I guess I don't quite understand how the breather works, and was wondering if someone could explain in a way that would pertain to problems I could run into, when painting the final drive. That was a run on sentance...English Guru's NEEDED!
    Thanks
    -Rick
    1979 XS1100 Standard
  • randy
    • Dec 2003
    • 4521
    Don't worry about it. The actual breather hole is way up under the cap. I can't imagine paint getting up there unless you're gonna DIP the whole drive in paint
      I just painted one and I simply wrapped the breather piece with tape. For the rattlecan job I did on it, it turned out great.
      • tw1980
        • Apr 2009
        • 662
        • Bend OR
        I painted mine no problems.But if you're worried about the breather then I think DG's suggestion has it covered.(no pun intended)But please be careful on your choice of colors.
        Terry
        1980 special (Phyllis)
        • TADracer
          • 1417
          • Kenner, Louisiana USA
          On my SF the breather is up under a little cone shaped cap. I just stuck a small piece of wood in the hole, painted everything the removed the wood with a little twist. That way the cap gets painted too.
          About the type of paint. I used Duplicolor wheel paint. I used the Aluminum color but they also make a dark metallic grey that is nice. After the color coat I applied a coat or two of the Duplicolor clear coat for wheels. Dirt and road grime just wipes off and the finish is very chip resistant to small stuff the wheels might kick up.
          Mike Giroir
          79 XS-1100 Special
          • foreda
            • 949
            • Southwest Louisiana
            Painting Final Drive
            First of all ..Paint. I use Dupli-Color wheel coating. It is a very hard paint and will resist chipping. The silver color looks almost like the original color. Use Aircraft stripper to strip the paint off, then ruff it up with a wire wheel brush. Then you can wipe it with carb cleaner to insure there is no grease. Prime with Dupli-Color primer, then paint. Put a wood dowel in the breather hole. I polish the breather to with a Dremel Tool and white rouge and it looks like chrome. Hope this helps.
            78 XS1100E Standard
            Coca Cola Red
            Hooker Headers
            1979 XS1100 Special
            1980 XS Standard
            2006 Roadstar Warrior
            • Crazcnuk
              • 2980
              • Hinton, AB, Canada
              Bright Purple
              '05 ST1300
