My XS11SG has an aftermarket headlight reflector with a 60/55W H4 bulb in it. The low beam failed. Kinda. While subsequently troubleshooting, the filament would light up if I rapped the bulb edge on something. It would also go on and off as I toggled the hi/lo switch but failed again when I put the headlamp back in the bike. Then it give full high beam when switched to high and super-dull high beam with the headlight warning bulb lit when switched to low; just like when it first failed.
WTF, it's in the bin now and the new bulb works fine.
I thought the RLU was supposed to switch the other filament on at full power, not just in a partial manner that don't even show the road at night.
So, is this because of having a different lamp or because the bulb low beam filament was only kinda failed or because the RLU is partially fried or what?
