i'm working out the final bugs on my xs (which is finally running right ...for now) and i couldn't help but notice how loud the kerker was now that i could actually legally go out on the street instead of just messing around in the neighborhood . which got me to thinking that it was probably time to repack it , so i went to take the megaphone off when i noticed there isn't a baffle at all . some joker tossed it out and jammed the end cap back in . well this won't do , it's just too damn loud , and this also means the previous owner strikes again , now that i've gone thru all the trouble of jetting it i'm probably going to have to re-jet again once i add a baffle , so there goes actually getting to ride this summer . me being furious aside , i'm going to need a baffle and i see mac sells one to fit the kerkers for $40 which is about all i can swing right now (just ordered a TON of parts) does anyone here use a kerker 4 into 1 with the mac kerker baffle ? and if so is it very loud ? think i would have to re jet ?
anyone used the mac kerker baffle ?
Although I have not used the replacement baffle, I can say that when I went from a straight through exhaust to a set of Jardine Spaghettis, I had to jet down a couple sizes on the main jet. The extra back-pressure did make the low end more drivable. Once the main jets were configured correctly, the top end didn't suffer much. It sure did before the rejet though.
Its kinda nice to retain most of my hearing after getting on the throttle though.
Ich habe dich nicht gefragt. -
Check your local laws concerning bikes over 25 years. In Washington State, it is required for all vehicles to be below a certain decible and must have a muffler installed...Except if your vehicle is over 25 years old! Then the law does not apply to you.
I have straight headers that are LOUD and not illegal. I carry a copy of the law around in my wallet, just in case!
-Rick1979 XS1100 StandardComment
I remember that 5k earsplitting harmonic. I don't miss it a bit.Ich habe dich nicht gefragt.Comment
mine is loud from 6-8k... i thought about the kerker baffle but i didn't know ho big the hole was in the end cap???" She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. "
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
mikes650 front fender
led's gallore...
renthal bars
gold valve emulators
vmax tensioner
Rifle fairingComment
TDogde, I have the same thing going on with my Kerker except that nobody has removed the baffle, it's just laying inside the megaphone. Something broke off on the inside when I hit a bump last year, but I can't even get the end cap off so the baffle is just laying there.
My problem isn't so much the noise as it is the lack of back pressure making tuning difficult. Don't get me wrong, a few dB quieter wouldn't be a bad thing as long as it means I can tune the carbs right.
Was there any trick to getting the end cap off, or is mine just holding on tight? I've removed the set screw from the bottom, but that thing just doesn't want to budge and I sure as hell don't want to mess up my exhaust any more than it already is.I know this, because Tyler knows this.
1980 SG
3J6 003509
Kerker 4-1 (sans baffles)
Fuse Block Upgrade
Mike's XS Green Coils
Pods w/Homemade Velocity StacksComment
i used a small metal cylinder (a thick spacer from something) from my nuts and bolts bucket that was slightly smaller than the hole in the end cap , there was a hole drilled thru the middle of the cylinder so i stuck a long bolt thru it , put a nut on the end , grabbed it with some vice grips , stuck it in the exhaust and yanked rearward 2 or 3 times and out came the end cap . wasn't too bad , there's a nice little lip just inside the hole on the endcap for it to grab onto . the muffler it's self tho is stuck to the header so badly it might as well be welded , good thing i don't need to take it off to replace the baffle .Comment
ok , i got the baffle today , completely forgot to take a picture , so here
thats the stock photo of it , but it is accurate . i must say , the bike sounds awesome , and is as quiet as i wanted , it is rich at 7k which i kind of expected but i'll get it tuned . i did end up having to grind the mating surfaces a little bit because the baffle didn't want to slide in far enough at first , the bench grinder made short work of it . so to anyone with a kerker that needs a baffle think about the mac baffle , it's $40 compared to the $120 kerker replacement baffle .Comment
