Ah crap...I broke my final drive!
  • Clerek
    • Jun 2009
    • 144
    • Spokane, WA
    I mistook the breather for the cap and I think I destroyed it...I am talking about number 34 in the picture below:
    It is apparently two parts that are welded together. The outer piece that is round and the inner piece that is cone shaped.
    Can I fix this or should I buy a new breather...?
    Anyone have an extra one?
    Thanks...
    -Rick
    1979 XS1100 Standard
  • cueball
    • Jun 2003
    • 375
    • Nth Albury NSW Australia 2640
    Did that myself
    Used silastic to put it back on. little bit on piece that goes into F/D and more between top of breather and flange of F/D housing. Just be careful not to block breather hole
    • Clerek
      • Jun 2009
      • 144
      • Spokane, WA
      I used vise grips to get it off. First I used it on the outer part and then on the cone shaped part...I don't know if the any of it survived. I can try to put it back together, and did some research on here before I posted, so I THINK I will be able to get it back together. Thanks for the tip. I may use JB Weld because I have some laying around. If the hole is totally wasted, is there anywhere i can get one REALLY cheap?
      -Rick
      • GARTHXS
        • 1631
        • Seattle
        D'oh!!
        D'oh!!!!!!!!!
        91 kwaka kz1000p
        Stock
        ( Insert clever quote here )
          • 2062
          I think i have a brand new one but need money for the part and shipping but it is new.Or you can contact Andreas Weiss.
          • Guy_b_g
            • May 2007
            • 790
            • Beverly Hills, Florida
            Another thought is to get a short bolt that fits the hole, drill it through the long axis, then securely insert a small piece of metal tube. You can put a piece of silicone tubing over the metal tube and route it up a few inches, then down to the swingarm where it can be secured with a wire tie. We used this method all the time on late model Moto Guzzi final drives because they didn't have a breather and had a habit of blowing seals when they got hot (we drilled the filler bolt).
            Guy
            '78E
            • xs11lover
              • 1433
              • Montoursville Pa
              Yup, I did the same thing about ten years ago, I have some extra's in the garage if you end up needing one.
              79 XS11 Special (Lazarus)
              79 DT 100
