Siezed Motor Need Help
  • rpgoerlich
    • Dec 2007
    • 643
    • Katy, Tx
    I use a borrowed borescope when inspecting the tubes on water chillers. Would at least let you see the cylinder walls without tearing it down.
    Thought I had seen a handheld one on sale, maybe HF?
    I think Kirmit77 might have a spare set of pistons & cylinders as well.
    Richard
    • kirmit77
      • Mar 2009
      • 464
      • Kingwood, TX
      Yep got an extra set that i still need to mic out... let me know
      Austin Ingalls
      MIDNIGHT FURY
      1979 XS1100 Special [Full Restore Project]
      XJ maxim rear air shocks
      KERKER 4-into-1 exhaust
      Pod Filters
      Money pit.......
      BLACKED OUT
        Yep. I have looked into an engine with a boroscope. BTW, if you do this after the engine has been running, the boroscope gets hot. DAMHIK.
        • Da-Bubble
          • Jun 2006
          • 353
          • Oklahoma City, OK
          #34
          Tod,
          I will ask my bud if he wants to come down this weekend. I'm sure he will. He was exstatic that it broke loose. Do you think it's a necessity to take the jugs off? How many gaskets do we need? If they are jacked up what do we do about it? Do we have to bore it out or can we just clean it up?
          (Kirmit thanks for the offer too. You get yours going?)
          Scott
          1979 XS11 Special (slightly modified)
          dubbed the "Mad Mosquito"
          MikesXs Pod Filters
          MikesXs 35k Coils
          8mm plug wires
          42.5 Pilots 142.5 Mains
          (Carb tune by GNEPIG Performance)
          Kerker 4-into-1
          Shaved emblems
          Progressive frt springs lowered 1.5"
          Progressive 11.5" rear shocks
          Harley Dyna rear fender chopped
          Custm side mt tag (apparently illegal)
          Custom Dual Headlights
          Lots of time and hard work.
            Well crap.. I hadn't heard anything back from you. It looks like I'm going to have to work tomorrow.
            As far as the bike, you'd just have to take off the exhaust, carbs, and cams, and tensioner. We can make a gasket for the tensioner (I may even have one) and I have a few valve cover gaskets and a couple stock head gaskets I'd let go cheaper than he could find somewhere else. But no, you don't have to remove the cylinders.. unless they are messed up from the rust. I have a little tool thing that I made to get those stubborn suckers off if they need it.
            So.. sorry I'll have to renig my offer for this weekend, but I could probably make it up there during the week next week if needed.
            In the mean time, you could do a compression check to see if breaking it loose broke a ring.
            • kirmit77
              • Mar 2009
              • 464
              • Kingwood, TX
              #36
              running GREAT! if you need the stuff just let me know
              Good luck
              Austin Ingalls
              MIDNIGHT FURY
              Pod Filters
              Money pit.......
              BLACKED OUT
