Carb break-down
  • rappin
    • 48
    • South Georgia
    Carb break-down
    Where can I find the best break-down of the carbs or a 79f?
    79 XS11
  • Wildkat
    XS Special Gurette
    • Apr 2004
    • 3416
    • Location, Location
    It's early... so please forgive me if I misinterpret your post.
    But if you're looking for a diagram of the carbs... you can try the Yamaha microfiche here:
    Yamaha Parts Catalog
    81 SH Something Special
    79 SF MEAUQABEAUXS
    81SH Nor'eas tah (Old Red)
    80 LG Black Magic
    78 E Standard Practice
    James 3:17
    “Alis Volat Propriis”
    Yamaha XS 1100 Classic
    For those on FB
    • xs11bobber
      • Jun 2009
      • 229
      • Cromwell, Indiana
      I think they're just about all the same actually. There's one in your Clymer's manual or here and other than the Yamaha fiche there's
      Bike Bandit
      CMSNL
      ...and I thought there was one more in my arsenal of links but I'm tired, haha HTH
      Josh Yoquelet -- I'm having dreams of my XS
      '79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
      '79 XS11SF "bobber"- Rotted in a pine tree for 10 years
      '81 Air forks w/23,000 miles
      New steering head races and bearings
      '78/'79 standard wire harness
      Drag bars, w/Mikes controls
      T.C.'s fuse block
      PNM Coils
      7mm Dyna Wires
      NGK Resistor Caps
      Custom 1" clutch and 9/16" MC
      http://xs11bobber.tripod.com
      • Wildkat
        XS Special Gurette
        • Apr 2004
        • 3416
        Well... sort of...
        There are differences between the earlier model carbs and the later model carbs that require the earlier models to run larger mains (as well as other subtle differences... some have adjustable needles, while others don't).
        But if you were talking about the basic just putting them together idea... yep... they are pretty much the same...
        79 SF MEAUQABEAUXS
        80 LG Black Magic
        James 3:17
        For those on FB
        • xs11bobber
          • Jun 2009
          • 229
          • Cromwell, Indiana
          Originally posted by Wildkat
          Well... sort of...
          I was referring to fiches only. Trust me, I've already noted the differences. Quickest way for me to tell is the carb tops. Small dimple on the newer models... unless they've been tampered with
          T.C.'s fuse block
          PNM Coils
          7mm Dyna Wires
          NGK Resistor Caps
          • mro
            • 4276
            • Hayward, California
            Has anyone noticed this ???
            Xsample
            79F carbs (BS34 II)
            2H7-14981-32-00 BODY, FLOAT CHAMBER EXCLUSIVE FOR CARBURETOR 4
            2A2-14981-32-00 BODY, FLOAT CHAMBER 3 2
            2G2-14981-32-00 BODY, FLOAT CHAMBER EXCLUSIVE FOR CARBURETOR 1
            81H (BS34 III)
            4G1-14981-05-00 BODY, FLOAT CHAMBER
            3U6-14981-05-00 BODY, FLOAT CHAMBER
            3U7-14981-05-00 BODY, FLOAT CHAMBER
            3W8-14981-05-00 BODY, FLOAT CHAMBER
            I've worked on II's and III's a few times
            "inspected" the float bowls and have found that there are some that will have different markings on the same set which I gather is meant to distinguish them from each other. Also have seen no discernable marks on other sets so have no idea how to determine which is which or if they were all the same. I've also purposely moved em around and could not tell any difference in how the engine ran. (could be I'm just not sensitive enough ? Missed three classes in my sensitivity training )
            Most likely difference is the jet in the bowl itself...
            mro
            Carb trivia poster
              I have noted that as float bowls go, the 78-79 and I believe the 80 models have the same drain on them. 80 might be different. The 81 models though had the drain screw going horizontal with a drain vertical outlet so you can put a tube on it. Thus the reason the Clymers manual suggest checking the float level on the bike, with bike leveled and using the drain tube, but only on the 81 model XS. IIRC, the drain screws point in different directions for 1 and 2 and 3 and 4 so they do not interchange.
