Broken idle mixture screw tip...tip
  • strom
    • 1577
    • Slovenia, EU
    OK... so you dont have to search...
    The problem is, there are still tips sicking out on the inside.. and I cannot put a pin on a pin to push it out.
    I tried with pliers, flat surface.. but that seemed to have a riveting effect. Any ideas? I figured a dentists drill, acid,... but thats a bit radical.
    Do any other idle mixture screws fit, or must they be original XS? I have 78E.
    LP
  • CA.XSer
    • 189
    • Jerome, ID.
    It ain't easy but can be done. I worked on mine quite a few times before getting the tip out. I don't remember what finally worked, but will look when I get home and see if anything jogs some brain cells.
    Gary
    79sf
    78e
      Last time I had to do this, I set up a very fine Dremel diamond burr in my drill press and drilled carefuly down through the brass. You could try the same thing with an appropriately sized numbered drill
      • Dennyz
        • 1151
        • Olympia, Washington
        I lightly ground a flat surface on the pin tip.
        Let me know where you find replacement needles. I do not recommend the K&L kits.
        DZ
        Vyger, 'F'
        "The Special", 'SF'
        '08 FJR1300
        • strom
          • 1577
          • Slovenia, EU
          Called my local yamaha importer... bout 10$/screw. Just get a code from the microfiche. It helps em find the part.
          LP
