Shocking Development
I have to refer to the manual every time I forget which coil fires which plugs...You're right!!
If you are getting spark on all 4 cylinders then......
Back to the carbs/fuel system you go! (Electrical/fuel/mechanical...)
Maybe there's something wonky going on in there. I know that if there's spark in a cylinder with a gas/air mixture then something happens: Ka-Boom! (Hopefully on the downstroke, please!)
I'm using OEM coils right now and I'm not impressed with the spark. The bike runs great, of course. But I've seen the light shows from some of the aftermarket coils and it's scary. Bright Blue sparks with a sharp CRACK that makes you step back and hope that it doesn't jump out to get you. Like I said, the stock coils appear "weak" but they do the job.
Try idling the bike for 5 minutes and then misting the pipes with water from a spray bottle. (Confirms which cylinders are really running.) Which cylinders are being lazy???
No problem, Doug. This'll all be a fuzzy memory soon and you'll be back to trying to figure out why bugs keep hitting you in the face instead of being drawn in to your headlight...
