Middle Gear Oil Filler
  • kevinbarzotelli
    • 23
    • Fox River Grove, IL
    Hi Guys
    i can't for the life of me undo the allen key filler for the middle gear oil.
    i have hit the allen key with a hammer & tried grips , i've stayed on WD40 & it
    wont budge. I've loosens the drain plug to (maybe) release pressure, but i don't want to drain the oil until i know i can undo the allen key filler hole.
    Any help greatly appreciated.
    Cheers All
    Kev
    • 8797
    Hammer and a cold chisel. Tap a groove in the side of the plug and spin it counter-clockwise. Works every time.
      A recent thread on this problem...
      • kevinbarzotelli
        • 23
        Thanks Guys
        All sorted.
        • schpiff
          • Mar 2003
          • 175
          • south central Wis
          Still curious
          I am not a machinist (but I did stay at some overpriced Holiday inn once).
          I too have had probs with the fill and drain plugs being a devil to break loose even after being careful not to overtighten them.
          I have always been able to "crack them loose" by applying pressure and giving a good sharp whack to the ratchet. I have used an allen wrench but its hard to get a good solid smack on them.
          My question for the machinist guys:
          What makes em stick so bad?
          Is it the flex of the head of the plug?
          The threads themselves seem to be cut fairly deep and turn easy.
          I am thinking I will take that advice earlier and next time I have em out I will
          use some teflon or something to make it a bit easier as the buggers do stick tight.
          '81 sh " Maime" The Nature of The Beast
            steel plug.........aluminum case..........bad combo. Find a thin fiber washer that fits perfect I.D..........or do like I do........snap a small pair of vice grips on outer edge of plug.......tap vice grip handle right smartly with a hammer.........works every time without slipping vice grips. Leaves a couple vice grip notches for next time. No known leaks, drain and fill to proper level with 75-140 Royal Purple and forget it! Have done the same with final drive, and between the two lost the annoying whine plus notice final drive case stays cooler. That's a good thing, less friction= less wear.
            • CatatonicBug
              • 6117
              • Clinton, UT
              I just add anti-seize to the threads. My final drive fill-plug has an external head, so I just use a socket to open that one.
              • morticiaann
                • Apr 2003
                • 90
                • Long Beach, CA
                Middle Engine Oil Fill Plug
                Drill the plug and use a screw extractor. I noticed nobody has told you about heat on frozen screws. Use a torch because metals expand and contract according to temperature. Also try an impact wrench (which might come with the 6mm allen wrench). If worse comes to worse; take the engine out of the frame and drill the plug out and cut new threads.
                [IMG]http://michaelwilliamandersen.ga[/IMG]
                • Ivan
                  • Jul 2008
                  • 2524
                  • Hutchinson KS
                  Instead of pulling the engine, just yanking the middle drive would be much easier.
                  Ich habe dich nicht gefragt.
                  • subike
                    • 167
                    • Christchurch New Zealand
                    Would it be worth the effort to see if somebody could find a plastic plug that would do the job as a mod?
                    Seeing as this problem is consistant across all models, suely we could find a compatable plastic cap off of another bike.
                    Or maybe look in the plumbing depot of a hardware store for a brass one. worth the effort?
                    http://i139.photobucket.com/albums/q...e/DSC00009.jpg
                    1980 XS1100 Std English Assembled, 378k miles
                    In stock untouched contion.
                    http://i139.photobucket.com/albums/q...e/seatside.jpg
                    1979 XS1100F Std NZ new,
                    Mikes XS coils
                    Jardine 4-1
                    Pod filters
                    Harley Davidson Rear Fender
                    Bullet signal lights
                    Twin 75mm headlights
                    Self made single seat
                      Someone put a replacement plug in my middel drive and all it does is leak. I've used teflon tape on it, and tightened it up good more than once, still leaks. I'd like to get ahold of the stock plug to put back in it if that would stop the leaking!
                      • Ivan
                        • Jul 2008
                        • 2524
                        • Hutchinson KS
                        They don't need to be much more than just snug when you put them in. It helps the next time you take it off if it hasn't been ham handed on the install.
                          • 8797
                          Still available new from Yamaha...
                          Plug P/N 90340-14046-00 $5.17
                          Gasket P/N 214-11198-01-00 $.99
                            Thanks Phil!
                            I'll get in touch with the dealer I am buying my clutch springs form and add that to the order.
                            • wa407mpp
                              • Jul 2007
                              • 717
                              You don't have to pull the engine to pull the middle gear assembly, You can pull out easily after removing a few things in the way and twisting it around a little.
                              Fastmover
                              lion". SHL
                              78 XS1100e
