anyone have a thought on how to seat a new filter on a petcock? It is an extremely tight fit...hard to believe you would ever find one floating in the tank if this is done right in the beginning. If I try to put presure on it, the tower collapses and if I try to tap it in via a punch I run the risk of goobering it up. Also, valve is now extremely tight to turn after new seals/gaskets. Normal break in required? Thinking about something stupid like getting a heat gun after it to soften it up...Stop me!
Took the tank to a local radiator shop and had it cleaned out and sealed. Local body shop painted it afterwards...looks PERFECT. Now if I can get the petcocks back on and oh yeah-the little wire on the sender unit isn't attached -can this be soldered back?
Having fun with this project so far.
