Piston clip installation tip
  • Filter
  • Piston clip installation tip
    http://www.youtube.com/watch?v=i3i6hFaIQ8g
    Hi all:
    I was putting on pistons today and came up with an easy way to get them on pretty quickly without using screw drivers or sharp tools which might damage something.
    I used a 3/8" dowel cut a groove in it using a hacksaw.
    I put the left side of the clip in the notch with the opening @ 6 o'clock, then I used the dowel starting @ 1 o'clock pushing down to 6 o'clock to get the clip in.
    posted a video on youtube but: don't think it came out too good.
    Any how it is an attempt to help out.
    Rick
    650SF
    XS1100SG Project bike
  • #2
    "SX11??" lol..
    Ummm... Nice video of your shoulder there at the important part!
    I use a good set of needle nosed pliers.. grab one side a bit back from the end, then stick the other end into the groove and start working it in.
    Glad you found something that works for you though.
    On a side note... it doesn't hurt to go to your local bike shop and pick up a couple extra. Most shops that have been in business for any time will have a few in the back for a buck a piece or something. That way, if you don't get one in and the clip shoots off to outer space somewhere, you have a spare. Kind of crappy to have one little clip stop progress on the whole rebuild. Yup.. I know this from experience..
    • #3
      Yeah I know I was so concerned about looking like I knew what I was doing that I didn't realize I was blocking the camera.
      Probably should have done the video over but the clip did go in as planned.
      Using my method none of the clips went flying I think I did a good job of describing it tho.
      650SF
      • #4
        Rickrod3;
        Are you located in Salem county or Bergen county?
        • #5
          I'm located in Bergen County.
          Rick
          650SF
