No, it wasn't the O-rings, but had something to do with a gasket or something discontinued that used to be in the cam chain galley... I think? lol.
Boy, we sound smart, don't we?
Tod, you say the O-rings are to keep the oil from getting UP between the cylinder/sleeves and the aluminum jugs/housing? I know the jugs need to be heated to over 400 degrees to get the aluminum to expand enough to slide the cast iron sleeves out of them, but the fit is tight enough to keep/maintain engine compression against the head. I realize that the head gasket has the metal compression ring around the piston hole area which gets squeezed against the head to seal the piston chamber, so I guess there really isn't any gas pressures that get to the area between the sleeves and jugs, and since the oil that could leak up thru that area is not under any real pressure, it's probably not that easy for it to possibly leak up to the head gasket? And there's actually oil flowing down thru ports in the head and cylinders as it returns to the crankcase, again under low pressure, and so if the head gasket is well sealed and the head isn't warped, then there shouldn't be any worry about any oil getting up around the cylinder sleeves and jugs/cylinder aluminum housing....IMHO!
