Carb ID
  • rappin
    • 48
    • South Georgia
    Carb ID
    How do I know what carbs I have? I can't find a number on them. On the one side it has MIC, and on the other side it says MIC MIKUNI KOGYO. I can't find anythinhg else on them. I had them ported, polished and benchflowed now that they are in peices I have the carb kits (APCO) 11-Y3084K for a yamaha XS1100' 79. I just can't find a number on them. Thaks for any replys.
    79 XS11
    Look at the idle mixture screws. If they are exposed, you have the early type (BS-34 II) carbs. If the idle mixture screws are down in a tunnel, then you have the later (BS-34 III) carbs. HTH
    • rappin
      • 48
      • South Georgia
      It looks like I have the 34-IIs. Thanks
      79 XS11
        Looks like you have the right carb kits then. Float level should be 25.7 mm with carbs upside down on bench.
