On 2 of the studs that go through the jugs and through the heads, have a rubber sleeve.
Should all of the studs have them?
I believe these sleeves made it a pita to remove the jugs.
Also one rings end gap was .439mm is it still okay to reuse since it is below the 1mm wear limit.
It's the only ring that does not fall between .2 and .4mm
Tia
Rick
Tia
Rick
