Hello,
I am building one XS out of two parts bikes and the oil filter case bolts are different on the two.
One has a spring loaded ball inside the bolt. The spring and ball are held in place with a roll pin. This is in addition to the larger spring and washer which goes below the filter.
The other bolt has nothing inside except the hollow cavity for the oil flow. The hollow bolt looks like it would allow unfiltered oil into the motor.
Any advice? Thanks, Eric
