exhaust bolts, can you blue thread?
  • greg maz
    • Feb 2008
    • 219
    • Arlington Heights, CA
    the temperature switch unbolts the headers pretty often, is there a proper assembling or is it just the halen in the tool set for life
    but would blue thread work?
    82 XJ1100 Klonk= SOLD
    No longer active member.
    Hey Greg,
    Whatcha been drinking?? That was a fairly cryptic post!
    However, I think I figured out what you were saying, that your header nuts...or are you using actual bolts, are working themselves loose due to the temp changes from cool to running and back to cool again, etc.!
    Red thread lock is designed for header studs and can hold up to the heat better than blue. However, if you're using the nuts, once the headers are tightened down to the point of crushing the exhaust gaskets, then there should be enough tension to keep them from backing out or loosening, provided the rest of the pipes are hung and supported properly. I've seen a few sets where folks just have short headers and straight pipes and have it all hanging on with just the header nuts!
    • Ivan
      • Jul 2008
      • 2524
      • Hutchinson KS
      You need to snug the exhaust nuts down when the bike is warm. If you do it cold, they will rattle loose. Just don't strong arm them when warm, or they can pull things apart when they cool down. Since a steel stud has a higher tensile strength than an aluminum head... well you get the idea.
      Ich habe dich nicht gefragt.
        Ivan, that makes absolutely no sense to me. Things swell when they get hot, not cold... but go ahead and make me look like like an idiot. It's not tough to do.
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          Right, the stud lengthens when it gets warm, so snug it when it is warm. When it gets cool, it will get even tighter. So you can't tighten it too much when warm, otherwise thermal contraction will break stuff.
          • greg maz
            • Feb 2008
            • 219
            got it
            now the header to the muffler right side needs welding again
            I put 50 mi on the bike like this, problematic?
