I cleaned many connections as been suggested by the gurus and measured my xj at a max of 15.5 or so volts, I have some yellow 1156 bulb fog lights and it seems to drop around one volt when I turn them on. Is there a voltage or watt calculation that would tell me if a couple 55watt driving lights would still allow the battery to charge. does it take just over 12 volts to keep battery charging? Also, I measured the voltage at the aux power connections, does it matter where you measure it.
