I know Mikes late model XS650 tank badges don't fit on our XS11s but what can you do if your wife takes the effort to secretly buy you a set for an anniversary gift?
Option 1) Say "send them back, they don't fit" and relegate oneself to a future of anniversary gifts of socks and underwear.
Option 2) Say "What a delightful and unexpected gift, thank you so much." and go make the bastards fit.
Yup, option 2) it is.
Mikes badges have lettering that's 1mm shorter than XS11 badges and they are 7mm shorter between the mounting holes but unlike the Yamaha golf cart badges they are properly curved so there's no need to heat them to ~130ÂșC in order to bend them.
Take off the tatty old badges and install Mikes badges by the front screw only.
Mark the fastener strips through the rear screw holes and remove the badges.
Centrepunch the mark and carefully drill through the strip with a 1/8" drill bit.
Tap the 1/8" hole with an M4 x .75 tap.
Be really careful not to drill through the gas tank doing this.
Install the new badges.
Elapsed time of install ~30 minutes including putting the tools away again.
