"Flash"ter cylinder
  • xs11bobber
    • Jun 2009
    • 229
    • Cromwell, Indiana
    "Flash"ter cylinder
    I've spent numerous hours looking for something like this...
    All I can find are ones that will fit a 1", 9/16", and 5/8" bar. Does anyone know of a company that makes one for our 7/8"?
    If unable to find one, that leaves me with 2 options:
    - I can buy the 5/8" and pray for enough material to have it machined to fit the 7/8" bars
    - I can have my top triple tree and clamp machined to fit either 9/16" or 1" HD bars.
    Option 2 would be a last resort because I already have the bars, grips, controls, and throttle sleeve in the mail to fit 7/8" bars.
    So, anyone feel free to chime in here...
    Josh Yoquelet -- I'm having dreams of my XS
    '79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
    '79 XS11SF "bobber"- Rotted in a pine tree for 10 years
    '81 Air forks w/23,000 miles
    New steering head races and bearings
    '78/'79 standard wire harness
    Drag bars, w/Mikes controls
    T.C.'s fuse block
    PNM Coils
    7mm Dyna Wires
    NGK Resistor Caps
    Custom 1" clutch and 9/16" MC
    http://xs11bobber.tripod.com
  • Bigleo
    • 93
    • Surrey BC Canada
    master cylinder.
    Hi, Partsnmore has them in black. If you wanted to polish them to aluminum it shouldn't be too hard to do. I think they were about $70.
    Leo
    1980 XS1100 Special
    1197cc Wiseco kit
    1978 cams
    4 into 1 Jardine with glasspack
    Keihin CR33 mm carbs
    K&N individual pod filters
    TKAT fork brace
    • petejw
      • 2269
      • sydney australia
      Hi Josh,
      This is off my 81 sports, was originally black
      with a bit of paint stripper and polish it comes up a treat.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • red bandit
        • 951
        • central michigan
        Buy the 1" and use a 1/16 shim around the bar. JAT.
        79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
        79 SF parts bike.
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          You might look for one off an early Venture on ebay. They had the same style bars as the XJ with longer risers, and have the solid metal MC and no plastic tank for the fluid. Also have the 7/8 diameter. They should buff up very nicely.
          Ich habe dich nicht gefragt.
          • xs11bobber
            • Jun 2009
            • 229
            • Cromwell, Indiana
            Any thoughts on where I could find a 1/16" shim with a 7/8" center?
            I could probably have one made that would replicate a bushing and then cut it in half. If the cut wouldn't give me enough pressure to squeeze the bar I could take a dremel to it and open the gap a little bit. Anyone think this would look hoky? fake? like garbage?
            I also like the stripper to a black finish then buff idea. I think that would save me some $$$ there so I'm going to look into that. Thanks for the ideas.
            T.C.'s fuse block
            PNM Coils
            7mm Dyna Wires
            NGK Resistor Caps
              How about start with a flat piece of 1/16" thick copper. By the time you bend it around the handlebar with one or two hose clamps, it will have the 7/8" ID you're after. A piece as wide as the MC clamping area, by just a hiar less than 2 3/4" long should do.
              • xs11bobber
                • Jun 2009
                • 229
                • Cromwell, Indiana
                After checking around the house and through toolboxes, trays, cabinets, cans and everywhere else... I have ZERO copper. Smallest size I found on eBay was 12x12. 1/16" copper is the equivalent to 16 gauge sheet metals. Anyone have a sliver lying around I can purchase?
                T.C.'s fuse block
                PNM Coils
                7mm Dyna Wires
                NGK Resistor Caps
                • xs11bobber
                  • Jun 2009
                  • 229
                  • Cromwell, Indiana
                  I wonder how thick the material is for something close to 7/8" ID copper pipe fitting... I don't even have any of those, lol.
                  T.C.'s fuse block
                  PNM Coils
                  7mm Dyna Wires
                  NGK Resistor Caps
                    Wrap the bar with electrical tape or similar just a bit smaller than the width of the clamp area. Easy to build up 1/16" and not be visible. That is how I got my left grip to stay on nicely.
                    • Ivan
                      • Jul 2008
                      • 2524
                      • Hutchinson KS
                      some .060 shim stock (feeler gauge) should work ok.
                        • 7735
                        Shim stock is available at a GOOD hardware store. So is aluminum bar stock as well as steel. Ace is the place......
                          Sleeve it?
                          I've spent numerous hours looking for something like this... - - - -
                          Hi Josh,
                          buy the 1" unit and cut a strip of 16 gauge aluminum sheet to wrap around the 7/8" bar to make an adapter sleeve.
                          BTW, are you sure the 9/16" & 5/8" numbers are bar sizes? More likely they are different piston sizes, and you'd better be sure you get the right size there, too.
                          • xs11bobber
                            • Jun 2009
                            • 229
                            • Cromwell, Indiana
                            Hi Josh,
                            Ok Fred... fill me in there too... piston sizes(aka bore)? Why do they need to be a specific size?
                            I was curious abot this AFTER bidding on one on eBay, so I think I already F***'d up. So's not to worry about it too much, I confinced myself as long as I could get a good seal on the banjo bolt with my brake line I'd be ok. Apparently, I'm going to screw myself. Please explain...
                            ...After doing some double checking, the 5/8 was a bore. I'm unsure about the 9/16 because I can't find it again. I'm pretty sure that one was a set of bars though.
                            T.C.'s fuse block
                            PNM Coils
                            7mm Dyna Wires
                            NGK Resistor Caps
                              Ok Fred... fill me in there too... piston sizes(aka bore)? Why do they need to be a specific size? - - - -
                              Hi Josh,
                              it's a ratio thing, equivalent to the leverage in a mechanical system. The master cylinder bore has to be a certain size compared to the size and number of seals in the calipers or the brakes don't work right. Too small and the lever pulls right back to the grip before the brake operates; too large and the brakes feel like wood.
                              Mike Morse's vintage brake site has a chart about it
                              On opening the site, click on "front brake master cylinder chart"
                              BTW, the stock bore of my XS11SG's m/c is 11/16". If you replace the stock fabric-wound brake lines with stainless steel wire-wound lines a 5/8" m/c will most likely work OK.
